90 percent retired
Massey farmer
PostPosted: Tue May 21, 2013 5:23 pm    Post subject: 90 percent retired Reply to specific post Reply with quote
90 percent retired, a few weeks ago I asked a question about my 1800 Oliver 3 pt and hydraulic lever problem. I poped the hydralectric cover off and found all my problems so thanks a lot. The lever problem was the washer that acts as a key on the shaft that runs to the control spools had sheered and the lever was not moving the spools like it should. The 3 pt problem was in the servo valve. I took it completely apart to clean and make sure all the balls were free and seating well. When I took one spring and ball out I found a piece of a broken spring in there. When I put it all together everything works great. Thanks for answering my posts.
J.Wondergem
PostPosted: Thu May 23, 2013 5:21 pm    Post subject: Re: 90 percent retired Reply to specific post Reply with quote
Thanks for letting us know what you found.
90 Percent Retired
PostPosted: Fri May 24, 2013 5:46 am    Post subject: Re: 90 percent retired Reply to specific post Reply with quote
You are welcome, glad to hear that things worked out for you.
Last edited by 90 Percent Retired on Fri May 24, 2013 5:47 am; edited 1 time in total
