nh 411 discbine
Goto page 1, 2  Next
playin in the dirt
PostPosted: Fri May 24, 2013 7:26 am    Post subject: nh 411 discbine Reply to specific post Reply with quote
I recently bought a new holland 411 discbine and am needing to change the oil in the cutter bar. Problem is my local dealer is telling I need the stand that came with it from the factory. The dealer does not have one and niether do I. Anyone out there now anything about this. I really want to change the oil in the cutter bar, I don't know how long its been since it was changed last. Any help is appreciated, but don't just tell me to take it to somewhere and have a professional do it. I work on my equipment because I don't trust someone else to do it right.
Shetland Sheepdog
PostPosted: Fri May 24, 2013 9:18 am    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
I have a 408, so the height may be different, but Showcrop has a 411, and may be able to help you! All you need is the height, and a few wood blocks will work just fine!
HTH, Dave
NEBeef
PostPosted: Fri May 24, 2013 9:46 am    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
If you know the correct capacity for the bar, can you just drain it and refill it with the correct amount?
lfc
PostPosted: Fri May 24, 2013 10:48 am    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
I never used the stand. It took so long for the oil to equalize I found it was easier just to pour in the exact amount of oil - thinking it was 50 oz but check the manual to be sure. I usually engaged the LH transport lock, removed the cutterbar endcap, and set the machine back down to drain the oil. Helps if it is warm, and I"d let it drain for a few hours to make sure the oil from the other end of the cutterbar had time to drain.
Just changed the oil in the modules in my new H7230 this week for the first time. The individual modules might be great as far as oil contamination is concerned, but it takes a long time to change them all!
showcrop
PostPosted: Fri May 24, 2013 5:17 pm    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
I don't have a stand but I could see from the picture in the owners manual that it is going to hold the left end up about nine inches so I just block it up like that. As lfc says warm it up good first.
wolfman
PostPosted: Fri May 24, 2013 5:19 pm    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
I always used a block of wood under the left shoe.
playin in the dirt
PostPosted: Sat May 25, 2013 12:56 pm    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
Do you know how much oil it holds?
NEBeef
PostPosted: Sat May 25, 2013 2:49 pm    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
playin in the dirt wrote:
(quoted from post at 21:56:17 05/25/13) Do you know how much oil it holds?
Wish I'd said that... Rolling Eyes
Shetland Sheepdog
PostPosted: Sat May 25, 2013 6:16 pm    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
Rolling Eyes I've got the stand, but I haven't been able to get the plugs out! Surprised
showcrop
PostPosted: Sun May 26, 2013 2:49 am    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
Shetland Sheepdog wrote:
(quoted from post at 19:16:33 05/25/13) Rolling Eyes I've got the stand, but I haven't been able to get the plugs out! Surprised
Dave, are you using a metric wrench?
Shetland Sheepdog
PostPosted: Sun May 26, 2013 3:45 am    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
Nope! Do I gotta?
May hafta go see my local "Snap-off" man!
Well, I found the part listing for 1 magnetic drain plug, but no size given & no check oil level plug listed! Dang!
showcrop
PostPosted: Sun May 26, 2013 8:59 am    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
(quoted from post at 04:45:25 05/26/13) Nope! Do I gotta?
Yes it is metric, as is everything on the header. The rest of it is SAE.
Shetland Sheepdog
PostPosted: Sun May 26, 2013 11:52 am    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
Makes sense, being made by Kuhn!
Put a bunch of miscellaneous parts on it a few years back, and had some red, some green & some orange! Rolling Eyes Laughing
Edit: Bought the red from NH dealer & the green/orange from JD/Kuhn dealer! Surprised
Last edited by Shetland Sheepdog on Sun May 26, 2013 11:54 am; edited 1 time in total
showcrop
PostPosted: Sun May 26, 2013 5:07 pm    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
(quoted from post at 12:52:10 05/26/13) Makes sense, being made by Kuhn!
So Brian must be your JD/ Kuhn Dealer?
Shetland Sheepdog
PostPosted: Sun May 26, 2013 5:23 pm    Post subject: Re: nh 411 discbine Reply to specific post Reply with quote
Ayup! But Jeff P in parts is the one I deal with most often!
Bought my 3910 from Sam back in the late 80's! Very Happy Came from Klem Tractor originally, and was traded for a JD 4x4.
Bought my 570 from Brian! Came from Brentwood originally, but was traded for a JD 348. Rolling Eyes
Now, I've got a MF/Vermeer dealer about a mile from the house! Wink
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
