New Idea Manure Spreader
Goto page 1, 2  Next
foxden
PostPosted: Sat May 25, 2013 5:19 pm    Post subject: New Idea Manure Spreader Reply to specific post Reply with quote
I have an old New Idea spreader. The drive chain for the paddles broke and after I put another link in the chain, it will not come out of gear...the paddles spin whether the lever is in the up or down position. What could I have done wrong...I"m not much of a mechanic? Thanks.
Nebraska Cowman
PostPosted: Sun May 26, 2013 1:49 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Do you have the chain too long so it is still engaging the sprocket when the lever is in the off position? Have somebody move the lever while you watch what it's doing.
Leroy
PostPosted: Sun May 26, 2013 3:48 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Give us a model and we can probably tell you number of links that are supposed to be in the chain. It sounds to me like you went around an idler wrong. I was thinking of the web feed chain, the chain for the beaters stays tight all the time and what throws that out is the ratchet feed. With model we can figure it out.
Leroy
PostPosted: Sun May 26, 2013 4:24 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
I was half asleep when I put this post on so I messed up in the reply, sorry. The beaters drive off the big sprocket on the left side and to throw out of gear the front sprocket that is connected to the lever is raised and to put it in gear it is lowered. If you put it around the guides wrong it cannot lift the chain off the large sprocket on the axle. The chain that I said stays tight all the time is on the right side and drives the web. That long left side chain depending on the model of the spreader will determine how many guides-tighteners it passes thru. And any of them that the chain misses will make that problem. You might be able to if you look close seewhere it had rubbed on things to tell if you put it on the correct side of the guides. Different model spreaders will be slightly different in that but all are simular. My parts books are all out in the truck right now and I cannot remember off the topof my head the exact pattern. I do have several spreaders setting here I can look at later. I was getting John Deere and new Idea mixed up as Deere drives the beaters different.
foxden
PostPosted: Sun May 26, 2013 5:56 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Many thanks, I'll look for the model number. For something that appears fairly simple, this has been a pain.
Dick L
PostPosted: Sun May 26, 2013 6:46 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Probly nothing you did wrong. The lever moves the roller to the cam that moves the ratchet. It could have broke or a cotter key came out and let the rod slip out. That would keep it engaged.
Nebraska Cowman
PostPosted: Sun May 26, 2013 7:28 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
That's what I got to thinking when I was out riding this morning. The chain is through the idlers wrong.
foxden
PostPosted: Sun May 26, 2013 7:35 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Dick, I think there are too many links in the chain.
When I replaced the broken one, the chain would not come together, so I put in a enough to bridge the gap. When the activation lever was let down, the chain almost touched the ground....I thought that didn't look right. Now, I don't know how many extra I actually added...more evidence of being a poor mechanic and trying to fix something I was unfamiliar with. Thanks for the response.
foxden
PostPosted: Sun May 26, 2013 7:36 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
That must be it....see my response to Dick. Thanks!
Leroy
PostPosted: Sun May 26, 2013 5:24 pm    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
This is for the web, not the beaters
foxden
PostPosted: Mon May 27, 2013 4:39 pm    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Ok, the spreader is a model 17. I moved the chain to where the idler from the lever in front lowers it to make contact with the large sprocket, or raises the chain away from the sprocket. But, it doesn't completely clear the sprocket and sometimes the paddles try to spin. Also, I put on a load and the chain started to slip over the drive sprocket a couple times, but if I stopped and backed up a few feet it would spin the paddles again. If I take any more links out, I don't know how the chain will reach to hook up again. Thanks
foxden
PostPosted: Tue May 28, 2013 6:41 pm    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Nebraska,
I counted the links and I think there are 66. This is a New Idea Model 17. I almost think it needs another link, so that the lever on front of the spreader can lift the chain off the drive sprocket. As it is now, if you put any more pull on the rod that moves the idler, it is so tight you can't get the lever to the top locking position.
foxden
PostPosted: Tue May 28, 2013 6:45 pm    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Leroy, it is a model 17. I counted 66 links. It seems very tight when raising the front activation lever to disengage the chain from the sprocket. If there were another link, I believe the idler would raise the chain higher. Thanks
Leroy
PostPosted: Wed May 29, 2013 6:23 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Just got out my No. 17 parts book. The main drive chain it lists 3 different ones. Steel link chain is No. 72 chain and 71 links and lots 371 to 417. 1739S Main drive chain, No. 70 tubular chain, 71 links. Order 0662-SRA, lots 371 to 378 with offset link assembly K2266A, Pin link assembly K2267A, And Roller link assembly K2268A. Then there is 0662SRA Maindrive chain complete, 71 links, No. 672 steel pintle chain lots 379 to 417 with Detachable link, No. 672 part number K3097A. Sprockets are same for all types of chain. Now Beater drive chain is 43 links of No. 62 steel chain. Wide spread is 42 links of the same 62 chain. So it looks like you are 5 links short but remember a worn chain of that length will stretch at least 3 links over what a new one will and a stretched chain will want to climb the teeth in the sprockets. So if your chain was wore enought to break it probably needs the whole chain replaced. The web chain is No. 67 or 67H chain of 67 plain links with 11 or 13 bar links nepending on lot number. And that spreader was built 1955 to 1960.
foxden
PostPosted: Wed May 29, 2013 8:41 am    Post subject: Re: New Idea Manure Spreader Reply to specific post Reply with quote
Leroy,
Wow...I think my head is about to explode! Bottom line here appears to be that I need more links to get the thing to disengage. Where should I check about buying the 71 link chain? I did not know about the offset links, pin links or roller link assembly....my main drive chain all looks the same.
Thanks for continuing to try to help me!
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
