770 clutch shaft and coupler
doug boll
PostPosted: Sun May 26, 2013 7:10 am    Post subject: 770 clutch shaft and coupler Reply to specific post Reply with quote
My dad just bought a 770. It does not have a power booster. I assume the splines on the coupler and shaft were worn so some genius welded the coupler to the shaft and at mid to higher rpm's it vibrates alot. Is the shaft the same as a 77 or 88 as they are more plentiful around here. Otherwise I can get the shaft re-splined and find a good coupler. Will the shaft come out without removing the bell housing?
J. Schwiebert
PostPosted: Sun May 26, 2013 7:30 am    Post subject: Re: 770 clutch shaft and coupler Reply to specific post Reply with quote
Going by memory here. But a 770 takes a longer shaft than either the 77 or 88 models. The 770 & 880 tractors use the same front frame. The 770 engine is shorter than the 880 engine so the clutch shaft has to be longer.
Brad Metcalf
PostPosted: Sun May 26, 2013 12:36 pm    Post subject: Re: 770 clutch shaft and coupler Reply to specific post Reply with quote
I think I have the shaft you need I will look email is open
