Ferguson 30 cutting off
Cliff Miller
PostPosted: Tue May 28, 2013 9:43 am    Post subject: Ferguson 30 cutting off Reply to specific post Reply with quote
I have a Ferguson 30 that starts right up and runs for just a few minutes, then cuts off. It usually will not start again for a half hour or more. I then start it up and it does the same thing. It runs for 3 - 5 minutes and cuts off. I tried different gas, cleaning the gas bowl, adding a lead substitute, and adjusting the carb, but nothing works.
s19438
PostPosted: Tue May 28, 2013 11:40 am    Post subject: Re: Ferguson 30 cutting off Reply to specific post Reply with quote
if it sputters, coughs and hiccups before shutting down it is most likely a fuel problem. if it just cuts out and dies most likely wiring/electrical.
trac
PostPosted: Tue May 28, 2013 1:01 pm    Post subject: Re: Ferguson 30 cutting off Reply to specific post Reply with quote
i'm thinking it's the condenser or key switch they will go bad as well it's happened to me the coil should run a little longer before it gets hot then stops.
jon corbett
PostPosted: Tue May 28, 2013 2:53 pm    Post subject: Re: Ferguson 30 cutting off Reply to specific post Reply with quote
i vote for condenser
Charles in Aus.
PostPosted: Tue May 28, 2013 7:17 pm    Post subject: Re: Ferguson 30 cutting off Reply to specific post Reply with quote
Next time it starts to cough pull out the choke , if it recovers , even a little bit then you probably have a fuel blockage in a secondary filter . If it does not recover then 'electrickery' is probably to blame . Coils have a habit of giving these symptoms , a small break opens up when hot and opens the circuit , then closes when cold which is enough to let the tractor start again .
2tractors
PostPosted: Wed May 29, 2013 4:39 am    Post subject: Re: Ferguson 30 cutting off Reply to specific post Reply with quote
Electrickery, I like that word, good one Charles.
Cliff Miller
PostPosted: Wed May 29, 2013 6:47 am    Post subject: Re: Ferguson 30 cutting off Reply to specific post Reply with quote
Thanks for all your ideas. It does seem to sputter a little before dying as if the gas is running out. If I pull the choke or give it a quick increase in speed, it recovers for a second or two and dies.
Jason S.
PostPosted: Wed May 29, 2013 8:02 am    Post subject: Re: Ferguson 30 cutting off Reply to specific post Reply with quote
Is the vent in the gas cap open?
