Super Major Injection Pump
88 Diesel
PostPosted: Tue May 28, 2013 10:47 am    Post subject: Super Major Injection Pump Reply to specific post Reply with quote
I have a Super Major with a Simms vacuum advance injection pump. The engine will not start, the fuel system is bled to the injectors. No smoke when the engine is cranking, the injectors have tested ok, the rack is not stuck, the plungers are not stuck. If this style pump is 180 out would that affect the operation?
Miles
PostPosted: Tue May 28, 2013 3:25 pm    Post subject: Re: Super Major Injection Pump Reply to specific post Reply with quote
Yes rotate coupling 180 degrees
Miles
Mike Farmer
PostPosted: Tue May 28, 2013 11:18 pm    Post subject: Re: Super Major Injection Pump Reply to specific post Reply with quote
You might also like to check which pump you have actually got so that you can time it perfectly. Off the top of my head I think there are 4 different sims vacuum pumps that will fit the major series. I will dig out all the details if you wish. Mike
88 Diesel
PostPosted: Wed May 29, 2013 4:12 am    Post subject: Re: Super Major Injection Pump Reply to specific post Reply with quote
Thanks, the pump cover reads: SPE4A75S 647. Is there any other identification marks on the pump?
Mike Farmer
PostPosted: Wed May 29, 2013 5:14 am    Post subject: Re: Super Major Injection Pump Reply to specific post Reply with quote
Hi. Ifthis comes out OK it should give you all the required detail to time it correctly.
Majorman
PostPosted: Wed May 29, 2013 11:50 pm    Post subject: Re: Super Major Injection Pump Reply to specific post Reply with quote
The picture in Mike's post showing the pump coupling is incorrect.
All Majors from 1952 to 1964 are on Number 1 cylinder when the coupling clamp bolt is below the drive shaft. If your timing marks line up with the coupling clamp bolt in that position you are 180 degrees out.
This picture is taken from the Fordson Tractor Workshop Manual. A rule of thumb we used when removing pumps:
Before removing the pump always check the position of this clamp bolt. If you do this and then put the pump back on with the marks lined up you will always be right.
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
