mf4235 steering problem
matt ken
PostPosted: Sun Jun 09, 2013 1:16 pm    Post subject: mf4235 steering problem Reply to specific post Reply with quote
THE STEERING of my mf 4235 becomes stiff after 1 hour work . the hydrolics slow down also. how can it be solved. it seems to be starved of oil
gbs
PostPosted: Sun Jun 09, 2013 4:24 pm    Post subject: Re: mf4235 steering problem Reply to specific post Reply with quote
may not be your problem but one of the newer mf models had a problem with the rubber section of the suction line collapsing causing the pump to cavitate
Masseynut(Australia)
PostPosted: Sun Jun 09, 2013 10:55 pm    Post subject: Re: mf4235 steering problem Reply to specific post Reply with quote
Hi Matt,
I'd be checking the suction screen on the intake side of the dual element auxillary pump.
If your tractor is a power-shuttle model after ser. no. L37030, there may also be a micronic strainer that needs cleaning as well.
There is also a second suction strainer for the lift hydraulics, located on the underside of the centre housing. Drain all of your transmission oil before removing the access plate.
If this fails to improve the steering at least, I'd be flow testing the steering side of your tandem auxillary hydraulic pump.
How many hours are on the clock? Has it been regularly serviced in it's lifetime?
Let us know,
Evan.
matken
PostPosted: Mon Jun 10, 2013 4:35 am    Post subject: Re: mf4235 steering problem Reply to specific post Reply with quote
Hi Evan,
Thanks for information.
can suction screen for auxillary pump be cleaned without draining oil
Thanks again
Matt
matken
PostPosted: Mon Jun 10, 2013 4:38 am    Post subject: Re: mf4235 steering problem Reply to specific post Reply with quote
Hi Evan,
Thanks
she has 5000 hrs
Not sure of service history
Matt
matken
PostPosted: Mon Jun 10, 2013 7:49 am    Post subject: Re: mf4235 steering problem Reply to specific post Reply with quote
hi guys
cleaned suction filter to aux pump.
steering working.
thanks very much.
Matt
