Craftsman LR7000 580.327630 7kW Generator
mordecai
PostPosted: Wed Jun 12, 2013 4:07 pm    Post subject: Craftsman LR7000 580.327630 7kW Generator Reply to specific post Reply with quote
Much older portable generator. In great shape but no spark.
Need source for magneto.
Bob
PostPosted: Thu Jun 13, 2013 9:14 am    Post subject: Re: Craftsman LR7000 580.327630 7kW Generator Reply to specific post Reply with quote
Got a picture of the engine?
greygoat
PostPosted: Thu Jun 13, 2013 10:10 am    Post subject: Re: Craftsman LR7000 580.327630 7kW Generator Reply to specific post Reply with quote
There"s lots of people on this forum who may be
able to help you, but we would need to know the
make and model of the engine, The word "Craftsman"
is meaningless to most people because Sears, itself never built anything, but rather, sourced
everything from outside venders, who changed
quite often.
jimg.allentown
PostPosted: Thu Jun 13, 2013 10:55 am    Post subject: Re: Craftsman LR7000 580.327630 7kW Generator Reply to specific post Reply with quote
Being a Craftsman generator, it is most likely to be a Tecumseh engine. Complete magneto assemblies are not available any more. Most likely, the problem is either points/condenser or coil - all of which ARE still available. You may also find that once you remove the flywheel, the magnets attached to the inside of it are loose or missing. I went through a similar problem with my craftsman generator. Flywheel magnets were bonded (at one time) to the inside of the flywheel. One was loose and just drifting along the inside of the flywheel and the other was still attached. I used JB Weld to reattach both. Still no spark. I put in new points/condenser. Still no spark....
Found that the points were not closing completely causing the loss of spark. After going over everything meticulously, spark returned and the generator started.
Next problem... no voltage output. After sitting for an extended period of time, the rotor will lose the residual magnetism that it needs to produce electricity. This problem requires re-initializing the generator.
Good luck!
mordecai
PostPosted: Thu Jun 13, 2013 1:32 pm    Post subject: Re: Craftsman LR7000 580.327630 7kW Generator Reply to specific post Reply with quote
Looks like a B&S 16HP model 401415
Bob
PostPosted: Thu Jun 13, 2013 8:28 pm    Post subject: Re: Craftsman LR7000 580.327630 7kW Generator Reply to specific post Reply with quote
Post new topic    Yesterday's Tractors Forum Index -> Stationary Engines All times are GMT - 8 Hours
