Hydraulic Pump
slifnom
PostPosted: Mon Jun 17, 2013 12:54 pm    Post subject: Hydraulic Pump Reply to specific post Reply with quote
Have any of you guys rebuilt a hydraulic pump on a 560 gas tractor? If so are there any recomendations?
Owen Aaland
PostPosted: Mon Jun 17, 2013 2:31 pm    Post subject: Re: Hydraulic Pump Reply to specific post Reply with quote
If your pump is worn so that it is low on performance the repair kit will not normally give you very good service. If the pump has much wear on it the bushings will be worn and very little wear is necessary before the gears start to rub on the housing and will cut out the aluminum. The kit only contains the side wear plates and soft parts.
DeltaRed
PostPosted: Mon Jun 17, 2013 5:04 pm    Post subject: Re: Hydraulic Pump Reply to specific post Reply with quote
Dont waste your time 'rebuilding'.Just buy a new one and be done with it.
slifnom
PostPosted: Mon Jun 17, 2013 5:20 pm    Post subject: Re: Hydraulic Pump Reply to specific post Reply with quote
Thanks for the replys. It is less than a hundred dollars between the rebuilt and the new! They both come with a 1 yr. guarentee
