1964 Ford Row Crop Lower Outer Axle Seals
mbuster
PostPosted: Mon Jun 17, 2013 4:45 pm    Post subject: 1964 Ford Row Crop Lower Outer Axle Seals Reply to specific post Reply with quote
Hello friends , Does anyone know where or have any old part numbers or know where to find these rear lower outer axle seals for a 1964 ford row crop tractor. I have found nothing yet. They look to measure around 3.530 inches outside diam and roughly 5/8 inches wide. Could really use some help. We had a standard D5NN4115B axle seal on hand and fits the axle shaft but outside diam is to small for the housing hole it is 3.500 inch just a shy loose fit.... Thanks Mbuster
Larry NCKS
PostPosted: Mon Jun 17, 2013 5:29 pm    Post subject: Re: 1964 Ford Row Crop Lower Outer Axle Seals Reply to specific post Reply with quote
Have you tried CNH (New Holland)? They should have that seal. Be prepared for the sticker shock though.
Sean in PA
PostPosted: Mon Jun 17, 2013 5:35 pm    Post subject: Re: 1964 Ford Row Crop Lower Outer Axle Seals Reply to specific post Reply with quote
Are you talking about the part labeled "7" in this parts drawing?
Parts site for Row crop rear axle
If so, the part number is NCB4233A and they appear to be readily available at partspring.com, messicks and most New Holland dealers.
mbuster
PostPosted: Mon Jun 17, 2013 6:06 pm    Post subject: Re: 1964 Ford Row Crop Lower Outer Axle Seals Reply to specific post Reply with quote
thanks sean in pa.....it is number 18 in the parts break down picture....the lower seal....the part number looks to be 87019059.....
