Super MTA IPTO leak advice
MattF-8
PostPosted: Mon Jun 17, 2013 5:27 pm    Post subject: Super MTA IPTO leak advice Reply to specific post Reply with quote
Hello, I have a MTA that is dripping oil out the side shaft of the IPTO. When parked it will leave about a 1 ½ circle of oil. Have any of you guys had any luck using stop leak products? I know I need to just take it a part and fix it right, but just don’t have time now. Thanks for the advice, Matt
sflem849
PostPosted: Mon Jun 17, 2013 5:27 pm    Post subject: Re: Super MTA IPTO leak advice Reply to specific post Reply with quote
I wouldn't use any stop leak products because the two $700 bands require a certain amount of friction to function properly and I wouldn't want to take my chances on a $1400 screw up. If it is only a 1.5" circle I would add oil once a week and run for a couple weeks until you have time to fix it right.
JMOR
PostPosted: Mon Jun 17, 2013 5:31 pm    Post subject: Re: Super MTA IPTO leak advice Reply to specific post Reply with quote
Exactly! Helps settle the dust.
MattF-8
PostPosted: Mon Jun 17, 2013 5:36 pm    Post subject: Re: Super MTA IPTO leak advice Reply to specific post Reply with quote
That is what I wasn't sure of and didn't want to screw anything else up! Thanks!
mkirsch
PostPosted: Tue Jun 18, 2013 4:17 am    Post subject: Re: Super MTA IPTO leak advice Reply to specific post Reply with quote
Even if you did add stop leak, it probably wouldn't work on a leak like that.
