regular clutch
doug st john
PostPosted: Tue Jun 18, 2013 5:48 pm    Post subject: regular clutch Reply to specific post Reply with quote
when I try to shift the tractor it takes a few seconds for it to go in gear is that normal? also when I push in the clutch to take it out of gear it won't release all the time what should I look for? thanks
Old-F20
PostPosted: Tue Jun 18, 2013 7:51 pm    Post subject: Re: regular clutch Reply to specific post Reply with quote
probably had the throwout bearing over greased and now its on the clutch disc. better take it apart and check it out, you don't want it to not disengage when you really need it to
Tom Fleming
PostPosted: Wed Jun 19, 2013 1:07 am    Post subject: Re: regular clutch Reply to specific post Reply with quote
In addition to what Old F20 said, I would also check the clutch shaft. Sounds also like the clutch disk is not sliding freely on the shaft. Could be full of mouse nests as well, which will can cause the symptoms you describe.
In either case, it requires popping the clutch off and take a look
RegulaRog
PostPosted: Wed Jun 19, 2013 4:23 am    Post subject: Re: regular clutch Reply to specific post Reply with quote
If it"s an early regular, it has the multidisc clutch. When the 3 holes that attach it to the flywheel get wallered out it will do that. I"m dealing with that on my "28 right now.
James Williams
PostPosted: Wed Jun 19, 2013 4:50 am    Post subject: Re: regular clutch Reply to specific post Reply with quote
My 28 regular has a multi disc clutch,Mine were stuck when i got the tractor.As far as I can remenber the out side disc is also a gear brake,I had it relined and it works perfect.With the belt pulley turning and in netural when I step on the clutch hard every thing stops quick.I beleive the disc clutch is a better clutch
jimmy
RegulaRog
PostPosted: Wed Jun 19, 2013 4:54 am    Post subject: Re: regular clutch Reply to specific post Reply with quote
James, did the big studs on the flywheel that mount the multidisc clutch have grooves worn in them, and if so, what did you do to repair them?
J.J. from Afton
PostPosted: Thu Nov 28, 2013 9:15 pm    Post subject: Re: regular clutch Reply to specific post Reply with quote
Probably a little late by now but I had had same issue with the pins on my Regular's clutch, I took them out, built them up with a few weld passes and turned them down in a lathe.
