620 bolt removal
Harrison58
PostPosted: Tue Jun 18, 2013 8:53 pm    Post subject: 620 bolt removal Reply to specific post Reply with quote
Im tearing apart my 620 clutch and I need to remove the bolt out of the crankshaft to get to the back half of the clutch. How do I do this whenever I try to turn the bolt the whole think turns. I can't figure it out. How do I remove this bolt. Thanks in advance
MSD
PostPosted: Tue Jun 18, 2013 8:57 pm    Post subject: Re: 620 bolt removal Reply to specific post Reply with quote
Try putting it in gear, engage the clutch and put the breaks on. Should hold to get it loose.
Mark-Ia
PostPosted: Tue Jun 18, 2013 11:30 pm    Post subject: Re: 620 bolt removal Reply to specific post Reply with quote
impact wrench.
Mike M
PostPosted: Wed Jun 19, 2013 4:40 am    Post subject: Re: 620 bolt removal Reply to specific post Reply with quote
You usually can't get an impact on them due to the tire in the way. Put a box wrench on it and SMACK it with a hammer. Remember lefty loosey. Make sure you get it good and tight too. Many were ran too loose causing worn splines.
You can also pull the fylwheel cover off and get a helper to hold it still for you or wedge a jackstand or something up onto the ring gear to hold it.
