D-17 change to negative groundelectronic ignition
larryg9
PostPosted: Tue Jun 25, 2013 7:58 am    Post subject: D-17 change to negative groundelectronic ignition Reply to specific post Reply with quote
do I just change the battery cables or does something else need to be done.
Kip-Utah
PostPosted: Tue Jun 25, 2013 8:05 am    Post subject: Re: D-17 change to negative groundelectronic ignition Reply to specific post Reply with quote
You also need to reverse the connections on the coil and ampmeter. If running a generator you need to reflash it and change the polarity.
Butch(OH)
PostPosted: Tue Jun 25, 2013 8:11 am    Post subject: Re: D-17 change to negative groundelectronic ignition Reply to specific post Reply with quote
Had to scracth my head a minute about what Kip said about the ammeter but I dont think you need to change it as it only knows the direction of flow. You need to re-polorize the generator and depending on how old the regulator is you might have to change it as the older ones were polarity specific, the new ones are not. You also need to reverse the low tension wiring on the coil as he said
Kip-Utah
PostPosted: Tue Jun 25, 2013 8:21 am    Post subject: Re: D-17 change to negative groundelectronic ignition Reply to specific post Reply with quote
Ammmeter not ampmeter and Butch is correct except with the new polarity the ammeter will show discharge when charging and vice-versa unless you reverse the wires.
old
PostPosted: Tue Jun 25, 2013 9:20 am    Post subject: Re: D-17 change to negative groundelectronic ignition Reply to specific post Reply with quote
Fill in the blanks. Why do you want to switch from + ground to - ground?? You changing to an alternator or what?? If you not changing to an alternator then there is no rime or reason to switch. So give us more info so we can help you help your self
John T
PostPosted: Tue Jun 25, 2013 12:58 pm    Post subject: Re: D-17 change to negative groundelectronic ignition Reply to specific post Reply with quote
Heres what you have to do:
YES reverse batt cables well duhhhhhhhh
YES swap ammeter leads or it would read bass ackwards
YES swap coil leads if its a coil distributor ignition
YES POLARIZE the genny BEFORE you start it
YES your VR has to be suitable for use at Neg ground
YES be sure new elec switch is for neg ground
orrrrrrrrrrrr how about NOT all that work n hassle n just buy a Pos grnd elec switch????
Your tractor your money your choice, we report now you decide
John T
