? for Tx Jim
usetob
PostPosted: Sun Jun 30, 2013 8:35 am    Post subject: ? for Tx Jim Reply to specific post Reply with quote
Jim, on a 457-S, every time I dump a bale, I get a errow code E4-31 ( oversise bale) even if I make a half bale I get the same code! Yes I.ve went by the book, and had JD out & they can"t figue it out eather! I would appreciate your input!
Tx Jim
PostPosted: Sun Jun 30, 2013 9:02 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
My experience with a 457 is very limited as only a very,very few were sold in my area. First thing I'd suggest is changing the bale size indicator switch. Maybe JD Seller,Tech 7 or some other knowledgeable person will chime in. Do you have a neighbor with a 457 that you could try a test of using their monitor??
RE261355 Sensor ADD 92.82 USD
usetob
PostPosted: Sun Jun 30, 2013 9:08 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
jIM, WE DID PUT A NEW SWITCH ON AND DOUBLE CHECKED IT! sorry caps lock! Do you know anyone that could help, you were my last chance!!
Tx Jim
PostPosted: Sun Jun 30, 2013 9:16 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
I'm not your last chance as there are many knowledgeable people on this site. Are all the pins in the electrical connection between tractor pointing straight out so as to make good connections?? Email JD Seller as he rarely visits the JD forum. I talked to him on the phone yesterday about my 467 "thanking him personally" for explaining to me how the netwrap senses the wrap application function. Sorry but I'm not at liberty to reveal his phone number.
Tx Jim
PostPosted: Sun Jun 30, 2013 9:19 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
Does the oversize alarm go off before bale is ejected??
usetob
PostPosted: Wed Jul 03, 2013 12:48 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
The alarm only goes off afre I eject the bale!
What is jd seller"s e-mail address?
thanks again
Tx Jim
PostPosted: Wed Jul 03, 2013 3:20 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
usetob wrote:
(quoted from post at 04:48:50 07/03/13) The alarm only goes off afre I eject the bale!
thanks again
Here it is. jd_seller at yahoo dot com I hope he doesn't mind me doing this.
lscott
PostPosted: Wed Jul 03, 2013 4:14 pm    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
Jim i see your replys, helping with J.D. balers, I have posted earlier today with problem i have with a 535 J.D. baler, the hyd. pump was leaking and i would have to fill resovoir after tying every 4th bale, i replaced the pump and it will work but the belt will be smoking hot just tying one bale,and belt will be ruined tying 2nd bale. whatching the pump when tying starts, every thing looks good then as arms start back to home position pulley on pump is struggling to turn and belt is slipping,as if the fluild is dead headed and can"t return,well thats what i"m thinking, I hope you can help me i don"t know what to look for.
Larry
North Texas
Tx Jim
PostPosted: Thu Jul 04, 2013 2:41 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
The hyd's on JD rd baler twine application is fairly simple as far hyd's are concerned.
Filter can get plugged
Spool valve can get dirty/rusty therefore not totally shifting each direction.
Speed control valve(parts key #14aAor B 2nd photo) orifice can get a speck of dirt in it. Try opening valve completely(CCW) and cycling twine arm
Have you been faithfully greasing zerts (parts keys #23 & 24)?
Check orifice(parts key #13) in hyd cyl for plugging as it contains a screen.
Does tying mechanism release tension on belt after tied bale is ejected and tailgate is closed??????????
Are you aware that you can cycle twine arms by raising bale size indicator to 3+ with pto running then pull rope to cycle twine arms
lscott
PostPosted: Thu Jul 04, 2013 3:44 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
Thanks for info, i will check orfice at cly #13, the tension on belt does release after opening and closing door.As for operataing pump with the 3ft. bale indicator in window, i have but do i use the door lock when doing this are just raise it, just raising door up and holding open with hyd. is what i"ve been doing and manually engaging pump.
Tx Jim
PostPosted: Thu Jul 04, 2013 4:53 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
lscott wrote:
(quoted from post at 07:44:09 07/04/13) As for operataing pump with the 3ft. bale indicator in window, i have but do i use the door lock when doing this are just raise it, just raising door up and holding open with hyd. is what i"ve been doing and manually engaging pump.
Either way is fine
Tx Jim
PostPosted: Thu Jul 04, 2013 7:38 am    Post subject: Re: ? for Tx Jim Reply to specific post Reply with quote
lscott
I just thought of something does tying system reset when gate is closed after ejecting a bale IE does belt have slack in it??
