Gp carb help
Daninsc
PostPosted: Sun Jun 30, 2013 12:02 pm    Post subject: Gp carb help Reply to specific post Reply with quote
On my 29 gp I took the carb apart to rebuild. The needle seat came out with the threads. I put some jb weld on it but when you tighten the nut it pulls it back out. Is this repairable or what do you do about it?
D-
PostPosted: Sun Jun 30, 2013 12:32 pm    Post subject: Re: Gp carb help Reply to specific post Reply with quote
There is some stuff that is expensive though. I've used it to put threads back in eng blocks and even in aluminum inj pump housings at the timing window screw holes. Molecular ?????? was the name I think, I will have to check. I just used some on an H carb at the fuel inlet hole.
You might also consider a heli coil if you can drill the hole straight. Is it 3/8 NF thread?
Mark-Ia
PostPosted: Sun Jun 30, 2013 1:19 pm    Post subject: Re: Gp carb help Reply to specific post Reply with quote
Cork Groth "The GP Guru" makes a insert that the seat will screw into. I had him do mine. It was the only way to fix it. He is located in Eldridge Iowa. His ph.# is 563-285-7009
