It LIVES!!
jon f mn
PostPosted: Sun Jun 30, 2013 6:02 pm    Post subject: It LIVES!! Reply to specific post Reply with quote
Worked on the 1160 today. It seems to run well. put an electric fuel pump on, then found that the problem was a stuck float needle. LOL oh well. Also fixed the mufflers and put the rubber bushings in for the shoe. Then took some shims out of the walker wood blocks. That is not a job for the faint of heart. I may have used some inapropriate words while doing that. Also found that the shaft in the clutch housing was seized. Had to get the little woman to help with that. I tied a strap to the lever and pulled it back with a bar and then the wife would push it down. Took a while workin it back and forth and sprayin with lube but at least she moves now. Here's a couple of videos of it running.
http://www.youtube.com/watch?v=WZhY2eFHx3Q&feature=youtu.be
http://www.youtube.com/watch?v=ZWB5gD6_-SM&feature=youtu.be
View user's profile AIM Address
Kow Farmer
PostPosted: Sun Jun 30, 2013 6:44 pm    Post subject: Re: It LIVES!! Reply to specific post Reply with quote
Great videos Jon. Are you going to put her to work in the small grain harvest this year? Did you get a corn head too? Sharp lookin' combine. Best of luck with it.
Kow Farmer Kurt
Case Nutty 1660
PostPosted: Sun Jun 30, 2013 6:45 pm    Post subject: Re: It LIVES!! Reply to specific post Reply with quote
Great job Jon,, she looks like she is happy,,, couple more things be sure to maintain the oil level in the governor VERY IMPORTANT,, also you need to check no load speed and reset if its not correct thanks for sharing
cnt
jon f mn
PostPosted: Sun Jun 30, 2013 6:51 pm    Post subject: Re: It LIVES!! Reply to specific post Reply with quote
How do you check the rpms and where? I'm thinking they are low.
jon f mn
PostPosted: Sun Jun 30, 2013 6:52 pm    Post subject: Re: It LIVES!! Reply to specific post Reply with quote
I'm hoping to. We'll have to see if the swather works out. Looks like the combine is going to be ok.
1031D
PostPosted: Sun Jun 30, 2013 7:03 pm    Post subject: Re: It LIVES!! Reply to specific post Reply with quote
Jon, looks good! Glad to see it run without ether or lighting your hand on fire! I got some wheat for you to try it on.
Case Nutty 1660
PostPosted: Sun Jun 30, 2013 7:11 pm    Post subject: Re: It LIVES!! Reply to specific post Reply with quote
at the beater shaft I will get my manual out and scan the pages you need from the vid I would say she is a little slow too that's what made me think of it knew there was more I needed to tell you on the phone LOL cnt
McKerrow630
PostPosted: Mon Jul 01, 2013 4:06 am    Post subject: Re: It LIVES!! Reply to specific post Reply with quote
Jon thank-you for sharing the video. Hope it works out that we see more videos of in the field. Yeah know I beginning ta think you have a lot of case equipment. How do you find the time to run all that stuff. With over the road semi work you do? Watch'en them videos bought ah smile over my face think'en about the "back'en the day" when dad pulled the 77 outa the back of the machine shed,wash off the bird poop. It had big deep toolbox that had the manual in it which showed where all the grease zerks where. Upon finshing grease'en my job was ta dump used eng. oil on in the cycial-bar before dad would fire-up the pto on the 700 to a idel. Watch the dust be'en shook-out that old girl. You knew oat season was coming. Sorry for ramble again. Thanks again Jon.
