mm u white smoke
manitoba farmer 12
PostPosted: Sun Jun 30, 2013 6:16 pm    Post subject: mm u white smoke Reply to specific post Reply with quote
i have a u that idles fine gives out the odd puff of white smoke then if it runs full throttle its fine when you throttle back all that comes out of the exhaust is white smoke is it a head gasket or something else
Ben Gomez
PostPosted: Sun Jun 30, 2013 7:29 pm    Post subject: Re: mm u white smoke Reply to specific post Reply with quote
i would say u have one of two problems anti-freeze in the engine oil, or more then likely u have a rod or main bearing going bad. From what u decribe i would drop the oil pan and clean it and start checking bearings. Good luck
manitoba farmer 12
PostPosted: Sun Jun 30, 2013 8:41 pm    Post subject: Re: mm u white smoke Reply to specific post Reply with quote
it sat for 8 years and there's no coolant in the oil
casecollectorsc
PostPosted: Mon Jul 01, 2013 3:20 am    Post subject: Re: mm u white smoke Reply to specific post Reply with quote
Diesel or gas engine?? If it's diesel it could just be unburned fuel because the engine isn't up to temp...
OliverNate
PostPosted: Mon Jul 01, 2013 5:28 am    Post subject: Re: mm u white smoke Reply to specific post Reply with quote
don't know how bad it bugs you but if you use it alot and never have to add anti-freeze i'd leave er be, i have a 37 Oliver Hart-Parr 70 that sat probly 8 years as well and got it running and it smokes blue/black/white like no other. so i just use it to keep the mosquito population down. hehe
manitoba farmer 12
PostPosted: Mon Jul 01, 2013 9:00 am    Post subject: Re: mm u white smoke Reply to specific post Reply with quote
its a gas engine
Kevin Moschenrose
PostPosted: Tue Jul 02, 2013 7:32 am    Post subject: Re: mm u white smoke Reply to specific post Reply with quote
White smoke is anti-freeze in the cylinder for sure especially if it's gas model. You could have one of few different problems a cracked head, cracked cylinder block or a bad and leaky head gasket. Just cause you idle it fast and it goes away doesn't mean it not doing it still. Antifreeze is no good in the wrong places and it is washing the cylinder walls down and before you know it your going to be doing a ring and bearing job on it. Plus looking for the broken part if it is something cracked.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
