800 swather hydraulic problem
dundeej
PostPosted: Sun Jul 07, 2013 4:11 pm    Post subject: 800 swather hydraulic problem Reply to specific post Reply with quote
I am have trouble with my 800 I have to come to a full stop to lift the head or the hydraulic pump pulls the belt to a almost stop so do I need a new pump or what do I do
Roger in Iowa
PostPosted: Sun Jul 07, 2013 6:04 pm    Post subject: Re: 800 swather hydraulic problem Reply to specific post Reply with quote
Is the belt slipping?
If it raises the head, sounds like the pump and all is working??
What head are you using?
Bob
Is the double "V" belt oily or worn (grooves in belt bottoming on "lips" at sides and center of drive pulley) making it slip easily?
dundeej
PostPosted: Sun Jul 07, 2013 7:05 pm    Post subject: Re: 800 swather hydraulic problem Reply to specific post Reply with quote
I have a 12 foot draper head and I have all new belts and all new chains on the swather the belt is not slipping you pull on the lever to lift the head it pulls the swather down and almost stops the head
buickanddeere
PostPosted: Sun Jul 07, 2013 9:51 pm    Post subject: Re: 800 swather hydraulic problem Reply to specific post Reply with quote
Does lifting the header lug the slant 6 ?
Is the belt slipping on the pump pulley or on the motor pulley?
As preveiously asked. Has somebody operated the swather with old worn belts until the point of failure. Which has worn the pulley grooves?
Over tighening the belt tension is not a substitute for new pulleys.
buickanddeere
PostPosted: Mon Jul 08, 2013 8:27 am    Post subject: Re: 800 swather hydraulic problem Reply to specific post Reply with quote
Pull on the lever? Isn't the header and reel height controlled with rocker pedals?
How much spring pre-load is on the lift cylinders?
M w J
PostPosted: Mon Jul 08, 2013 9:24 am    Post subject: Re: 800 swather hydraulic problem Reply to specific post Reply with quote
Is that pump mounted on the header and driven by the belts that run the head It may be the head drive belt slipping causing the pump to slow down.
