IH 440 baler knotter frustrations
Corona Boy
PostPosted: Mon Jul 08, 2013 4:01 pm    Post subject: IH 440 baler knotter frustrations Reply to specific post Reply with quote
Inside knotter will loop and
hang up on bill hook shaft. Not
every time. But the most
without is five bales. Cut the
twine off hook,run twine thru
twine disc and tie off. Good for
3 or 4 more bales. I'm thinking
twine tension on that one
knotter. Suggestions?
Comments? Ideas?
North Vale - PA
PostPosted: Mon Jul 08, 2013 5:31 pm    Post subject: Re: IH 440 baler knotter frustrations Reply to specific post Reply with quote
on a JD baler, that is a sign the tucker fingers are not pushing the twine into correct position.
jlewis457
PostPosted: Mon Jul 08, 2013 6:13 pm    Post subject: Re: IH 440 baler knotter frustrations Reply to specific post Reply with quote
I have a 430 and i think it is the same. First clean every speck of string out of the knotters, second make sure all the string is cleaned out of the knotters that is how important it is. make sure you are using 9600 twine not small round bale twine. if I rember right you dont have to thread the string through the knotters just through the needle and tie off to the arm. I fought mine for over four hours one day just enough for a lite shower to ruin all my hay and when the dryed the next day it worked perfect mine always misses when it comes to the end of a ball of string and I just stop clean the knotter and go on mine will never miss after that. Watch after bragging on it that thing will make me pay
I hope this help you
John
donjr
PostPosted: Mon Jul 08, 2013 6:23 pm    Post subject: Re: IH 440 baler knotter frustrations Reply to specific post Reply with quote
NV- totally different knotter. JD is similar to a NH, IH is a Mc Cormick design. After the bale is tied, it leaves two little 'rabbit ears' in the knot.
matt robinson
PostPosted: Mon Jul 08, 2013 6:50 pm    Post subject: Re: IH 440 baler knotter frustrations Reply to specific post Reply with quote
I bale with a 430 and have had the same problem. I used to get the same results you are getting every 5 bales. Since then I loosened the bill and kept it well lubricated with light penetrating oil. also do not over grease the knotters for that will cause twine to get stuck too. you should grease every 1000 bales and grease lightly. that worked for me its worth a shot
Paul swpa
PostPosted: Mon Jul 08, 2013 8:23 pm    Post subject: Re: IH 440 baler knotter frustrations Reply to specific post Reply with quote
Could be a lot of things going on. Twine tension is a good place to start. Also check the keeper settings and helper spring on the knotter, new twine knives and position they are put on in can sometimes help. I saw on here somewhere that plunger slop can be part of the problem too. That's what I'm down to on my 440 to try and solve this problem. It worked great when we got it, so thinking something is worn.
GordoSD
PostPosted: Mon Jul 08, 2013 9:10 pm    Post subject: Re: IH 440 baler knotter frustrations Reply to specific post Reply with quote
Sounds like the wiper arm is not pulling the know off the hook. Do you have the manual? That is an absolute MUST for a baler. Dozens of adjustments to me made in a critical order.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
