fordson f clutch problem
john friend
PostPosted: Mon Jul 08, 2013 5:19 pm    Post subject: fordson f clutch problem Reply to specific post Reply with quote
I installed new coils on my fordson f got it running tried to shift it in gear seems like the clutch is not disingauging it just grinds will not go in any gears tractor been sitting for many years outside it was full of grease it seems to shift fine wen not running any suggestions thanks
ddwark
PostPosted: Mon Jul 08, 2013 6:39 pm    Post subject: Re: fordson f clutch problem Reply to specific post Reply with quote
Sounds like clutch is stuck to fly wheel or pressure
plate or both
ddwark
john friend
PostPosted: Wed Jul 10, 2013 6:48 am    Post subject: Re: fordson f clutch problem Reply to specific post Reply with quote
I split tractor apart disassembled clutch it looked ok cleaned and put back together looked in book figured out how to adjust clutch needed to remove steering section removed steering gear and pin turned clutch adjuster to the right two clicks reassembled started tractor clutch works fine thanks for your input
Bernie/MA
PostPosted: Wed Aug 07, 2013 7:47 am    Post subject: Re: fordson f clutch problem Reply to specific post Reply with quote
Where did you find a book?
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
