oliver 1650 engine trouble
cody w
PostPosted: Wed Jul 10, 2013 1:09 pm    Post subject: oliver 1650 engine trouble Reply to specific post Reply with quote
i have a 1968 oliver 1650 gas. it has a knock in the motor at mid throttle on up. everyone on here told me it was most likely wrist pins. but i discovered the spark plug in the number 1 cylinder was loose and stripped. it is a bigger plug so i assume it was drilled and retapped years ago. the compression is blowing right by no matter what i do you can hear it loud and clear especially when you start it and shut it off. this cylinder is where i hear the knocking. could this be the cause of my knock? if i take the muffler off the sound almost goes away but if i put it back on it comes right back. any thoughts?
mechanicfred
PostPosted: Wed Jul 10, 2013 5:39 pm    Post subject: Re: oliver 1650 engine trouble Reply to specific post Reply with quote
See if you can get a spark plug thread repair kit.
Dick W.
PostPosted: Wed Jul 10, 2013 6:11 pm    Post subject: Re: oliver 1650 engine trouble Reply to specific post Reply with quote
Install a heli-coil in the spark plug hole. It might be 18mm thread size.
hd6gtom
PostPosted: Thu Jul 11, 2013 5:31 am    Post subject: Re: oliver 1650 engine trouble Reply to specific post Reply with quote
Cody the local NAPA store should have a kit complete with thread cutter to cut new threads in the head then you install a threaded sleve in the hole using Locktite. I've done several and never had the sleves come out. I like them better than heli-coils. The knock could be the loose plug, carbon buildup, wristpin, etc.
codyw
PostPosted: Thu Jul 11, 2013 7:52 am    Post subject: Re: oliver 1650 engine trouble Reply to specific post Reply with quote
Thanks guys
