1800 carb
rosedale123
PostPosted: Thu Jul 11, 2013 9:21 am    Post subject: 1800 carb Reply to specific post Reply with quote
I have taken the carb apart to clean an there is a "device" that consists of a shaft with a spring on it and a brass "piston" on either end. the one "piston is in the top 1/2 and the other in the bottom 1/2 ( they fit in a bore/hole ). The one piston is not attached to the shaft so I assume it is broken. the id #'s on the carb are 3-132 and a round brass tag - 14990B. I think it is a MS and it is heavy so I assume it is cast.
What is the "broken" part , I assume it is needed , and where cold I get one.
J. schwiebert
PostPosted: Sat Jul 13, 2013 6:38 pm    Post subject: Re: 1800 carb Reply to specific post Reply with quote
Sounds to me like it is the Zenith that replaced the aluminum M-S carburetor
