Ol' Smokey compression test
Fuddy Duddy
PostPosted: Sat Jul 13, 2013 5:22 pm    Post subject: Ol' Smokey compression test Reply to specific post Reply with quote
I'm not sure what's going on here with Ol' Smoky, 2N 12v.
Put in new Blue streak points and plugs. Can't get it to run. Pulled distributor and rechecked everything. All looks good. All plugs are firing. But only #3 has becomes black and sooty. Others are clean with oil on them.
Did a compression test:
#1 130 dry 130 wet
#2 95 dry 110 wet
#3 120 dry 130 wet
#4 120 dry 130 wet
That's not the results of a completely worn out engine.
However, this engine has always burned about a quart of oil per gallon of gas.
I've used all the miracle snake oils in the engine. ATE, MMO Sea Form and such.
Old compression test was"
April 7, 2011
DRY WET
#1 110 120
#2 70 90
#3 60 80
#4 110 120
I think the engine is just about worn out.
But the new compression test has me wounding?
Roger in Iowa
PostPosted: Sat Jul 13, 2013 5:53 pm    Post subject: Re: Ol' Smokey compression test Reply to specific post Reply with quote
A quart of oil per gallon of gas, I would say the oil control rings are gone, but with good compression??
souNdguy
PostPosted: Sat Jul 13, 2013 5:56 pm    Post subject: Re: Ol' Smokey compression test Reply to specific post Reply with quote
if most of the plugs are wet oily. it's almost always running a wet test.. Smile
Fuddy Duddy
PostPosted: Sat Jul 13, 2013 6:03 pm    Post subject: Re: Ol' Smokey compression test Reply to specific post Reply with quote
I forgot to mention, It has always had 40# oil pressure idling and 35 working.. Seems to me it should at least still crank up. Why soot on only one plug. Seems it's only hitting on that one cylinder.
old
PostPosted: Sat Jul 13, 2013 6:37 pm    Post subject: Re: Ol' Smokey compression test Reply to specific post Reply with quote
Check your distributor over real good and make sure the points open to 0.015 on all 4 lobes. You may have a distributor problem and not firing on all 4. Also try the hand trick on the air intake and make sure you have good suction on the air intake of the carb. I should have told you about a 2000 that was for sale in this area by the way but it sold already
FarmerHR
PostPosted: Sat Jul 13, 2013 9:02 pm    Post subject: Re: Ol' Smokey compression test Reply to specific post Reply with quote
Last winter the engine on our 8N was rebuilt with a lot of excellent help from this site. The compression test gave good numbers both dry and wet. Very little difference between the two. It burned about a quart an hour. I think my dry test was really also a wet test.
When the engine was taken down, number 1 oil control ring was broke and also a section was missing on oil control ring 4.
After rebuild, the oil burning, smoke etc went away.
Hoper this helps.
NOXJohn
PostPosted: Sun Jul 14, 2013 2:42 am    Post subject: Re: Ol' Smokey compression test Reply to specific post Reply with quote
Try changing the plugs.
Fuddy Duddy
PostPosted: Sun Jul 14, 2013 4:01 am    Post subject: Re: Ol' Smokey compression test Reply to specific post Reply with quote
Plugs are brand new
Bill Rowles
PostPosted: Sun Jul 14, 2013 6:40 pm    Post subject: Re: Ol' Smokey compression test Reply to specific post Reply with quote
It seems the oil burning may have loaded the valves and combustion chambers with carbon deposits. If it were mine, I would pull out the pistons and check rings and valves along with a good de-carboning of the top end......bearings are probably OK. Check to be sure the muffler is not plugged with carbon too!
Roger in Iowa
PostPosted: Mon Jul 15, 2013 8:19 am    Post subject: Re: Ol' Smokey compression test Reply to specific post Reply with quote
I think that one cylinder has a problem. Probably broken oil ring in that one cylinder or other problem. Soot is from not burning clean.
