Wheel Bolt Pattern
Juicybusa2
PostPosted: Sat Jul 13, 2013 7:56 pm    Post subject: Wheel Bolt Pattern Reply to specific post Reply with quote
Anyone know if wheels from a 2910 Ford will fit a NAA? Stock
tire sizes are identical
old
PostPosted: Sun Jul 14, 2013 7:07 am    Post subject: Re: Wheel Bolt Pattern Reply to specific post Reply with quote
Fronts will and if it has the 6 loop rims on the back those will switch out also
Juicybusa2
PostPosted: Sun Jul 14, 2013 9:24 am    Post subject: Re: Wheel Bolt Pattern Reply to specific post Reply with quote
Solid rear wheels with turf tires-nice setup for my jubilee if rears will fit. 3 hrs away so can't test fit
old
PostPosted: Sun Jul 14, 2013 10:27 am    Post subject: Re: Wheel Bolt Pattern Reply to specific post Reply with quote
If both have the same number of lug bolt good chance they would fit
Ultradog MN
PostPosted: Sun Jul 14, 2013 11:42 am    Post subject: Re: Wheel Bolt Pattern Reply to specific post Reply with quote
I'm pretty certain they wont.
2910 had a much heavier, double reduction rear axle. I don't know why they used such overkill on a 36 hp tractor but...
The rear bolt/lug nut pattern on a 2910 should be 8 on 8" instead of the 8 on 6" found on most of the smaller Fords from the 8Ns through 1982 or so 3600s.
I could be wrong but I would ask the seller to measure the bolt circle for you before running off on a wild goose chase.
Juicybusa2
PostPosted: Sun Jul 14, 2013 12:49 pm    Post subject: Re: Wheel Bolt Pattern Reply to specific post Reply with quote
FYI the seller returned my call. Fronts would work but his turf tire rear wheels are 8 lug 8 in pattern NAA is 8 lug 6 in pattern That sux:(
