patching holes
harrison atkinson
PostPosted: Sun Jul 14, 2013 1:36 pm    Post subject: patching holes Reply to specific post Reply with quote
the previous owner of my ford 2n tractor drill hold in a lot of the parts such as the instrument panel and the fenders, would like to know if there is a way to patch them
glennster
PostPosted: Mon Jul 15, 2013 8:24 am    Post subject: Re: patching holes Reply to specific post Reply with quote
best way is to cut and fit sheet metal patch panels and then mig weld them in.
BobinMi.
PostPosted: Wed Jul 17, 2013 2:14 pm    Post subject: Re: patching holes Reply to specific post Reply with quote
Use a backup such a copper behind the hole and mig weld it in. Just spot it in to keep heat down. Grind smooth, and finish.
Stephen Newell
PostPosted: Thu Jul 18, 2013 12:43 pm    Post subject: Re: patching holes Reply to specific post Reply with quote
Welding is the best way but if you don't have a welder you might put a piece of fiberglass cloth about 2"x 2" on the back side of the hole with fiberglass resin and then fill the hole with bondo. Be sure to roughen the metal before putting the cloth on.
dr sportster
PostPosted: Fri Jul 19, 2013 10:29 am    Post subject: Re: patching holes Reply to specific post Reply with quote
I have done this on antique motorcycle fenders. I find it best to have little plugs to weld in . It is time consuming but I make them in the lathe. Then back up with copper while welding.
FBH44
PostPosted: Sun Jul 21, 2013 5:02 am    Post subject: Re: patching holes Reply to specific post Reply with quote
From time to time I've just put in nice galvanized bolts, leaving the bolt heads showing, sometimes chrome screws, that look like they belong there. Sometimes it looks OK.
Post new topic    Yesterday's Tractors Forum Index -> Paint and Bodywork All times are GMT - 8 Hours
