M602 Bracket
cleddy
PostPosted: Tue Jul 16, 2013 1:57 pm    Post subject: M602 Bracket Reply to specific post Reply with quote
I've been working on my engine starting with a crankshaft,bearings,rings,new heads,valves re-ground,clutch,radiator, and about anything else from transmission forward and since it was so accessable I've been cleaning and painting with dyna-brown paint as it goes back together. Just about ready to get the front back on the back now.
I have this old bracket that came with the tractor and bolts across on the front end just in front of the fan belt. We never knew what it was and threw it in the scrap but if anyone can tell me what it is for maybe I should paint it and put it back on. Any ideas??
cleddy
Captainhookerus
PostPosted: Tue Jul 16, 2013 2:44 pm    Post subject: Re: M602 Bracket Reply to specific post Reply with quote
Its a front mounted cultivator bracket.
I have on one of my universal 335s but never saw one on a 602.
Alan K
PostPosted: Tue Jul 16, 2013 3:00 pm    Post subject: Re: M602 Bracket Reply to specific post Reply with quote
I used to have a front mount cultivator that was on an M602, but never saw one of the brakets.
oleclint
PostPosted: Tue Jul 16, 2013 7:28 pm    Post subject: Re: M602 Bracket Reply to specific post Reply with quote
That bracket was on one of our 5 stars. It holds up the outer ends of a 4 row cultivator. It worked just like it was designed to . Do not throw it away! clint
majorlucas
PostPosted: Fri Jul 19, 2013 5:12 am    Post subject: Re: M602 Bracket Reply to specific post Reply with quote
Finally, something I know! I have a 602 (propane) with that same cultivator bracket and have used it many times with my front mount 4 row cultivator.
Alan K
PostPosted: Fri Jul 19, 2013 8:15 am    Post subject: Re: M602 Bracket Reply to specific post Reply with quote
Do you have any pictures of your 602 with the cultivator on? Ive only seen pictures in literature.
majorlucas
PostPosted: Fri Jul 19, 2013 11:14 am    Post subject: Re: M602 Bracket Reply to specific post Reply with quote
Not that I know of...... We haven"t had it mounted in 10 or so years, but when I go back to row crops, I"ll have to dig it out......
I am not sure what brand of front mount it was. It may have been a Massey, since that was what Dad started farming with.
I"ll keep an eye out for pictures and if I find one, I"ll post it.
Marty
cleddy
PostPosted: Fri Jul 19, 2013 2:00 pm    Post subject: Re: M602 Bracket Reply to specific post Reply with quote
Thanks for all the replies. I would like to see a picture of that also. We used a 4-row Allis-chalmers cultivator which had a square tube across the front(Bent Square tube after farmerized) and tie rods up near the top corners of the radiator. I ended up with 1/2" x 2" steel frames on the front of all the tractors with drawbars welded on to push wagons and strong enough to carry a 110 gallon fiberglas tank. No wonder all of this stuff is kind of beat up??cleddy
JK2
PostPosted: Sat Jul 20, 2013 6:41 am    Post subject: Re: M602 Bracket Reply to specific post Reply with quote
My 4 Star Super has a similar bracket that came with the 4 row cultivators. I think these brackets were only used on the later cultivators that had solid mounting bars instead of hollow tubes.
Post new topic    Yesterday's Tractors Forum Index -> Minneapolis Moline All times are GMT - 8 Hours
