Rear Break away leaking
KRS_MED
PostPosted: Tue Jul 16, 2013 3:43 pm    Post subject: Rear Break away leaking Reply to specific post Reply with quote
Rear SCV remotes are leaking on my 2150. I bought the SCV and remotes used but it all bolted right. The number on the breakaway coupler is R39109, but I can't cross that number. It has the caps on top, with the levers on bottom. It very hard to connect the hydraulic line. It seems that the coupler is not going in far enough. Plus they leak when nothing is hooked up but don't leak when you finally get line in. The hydraulic hose has new coupler on it from JD (they made the line). Any help or advise on what kit or how to repair would be a great help.
Keith
Tx Jim
PostPosted: Wed Jul 17, 2013 3:32 am    Post subject: Re: Rear Break away leaking Reply to specific post Reply with quote
It appears your breakaway coupler is one of the earliest styles. It fits many different models from the 20 through 40 series utility tractors. I found this in a 2020 PC Read parts description for parts key #22 AR52621 COUPLING 1 R.H. (SINGLE) (MARKED R39109).
Leaking out of the barrel with nothing attached is an indication that the ball(parts key #25) isn't seating. AR82570 Breakaway Coupler kit ADD 24.46 USD
KRS_MED
PostPosted: Wed Jul 17, 2013 12:40 pm    Post subject: Re: Rear Break away leaking Reply to specific post Reply with quote
Jim the diqagram isnt showing up? Thanks Keith
Tx Jim
PostPosted: Wed Jul 17, 2013 12:57 pm    Post subject: Re: Rear Break away leaking Reply to specific post Reply with quote
KRS_MED wrote:
(quoted from post at 16:40:44 07/17/13) Jim the diqagram isnt showing up? Thanks Keith
You're correct as I forgot to upload photo.
KRS_MED
PostPosted: Thu Jul 18, 2013 5:56 pm    Post subject: Re: Rear Break away leaking Reply to specific post Reply with quote
Thats it thanks a lot Keith
KRS_MED
PostPosted: Thu Jul 18, 2013 6:02 pm    Post subject: Re: Rear Break away leaking Reply to specific post Reply with quote
Parts ordered and on the way. Thanks Keith
