MF DEO 25 hay rake drive pulley
John Kruer
PostPosted: Wed Jul 17, 2013 4:49 pm    Post subject: MF DEO 25 hay rake drive pulley Reply to specific post Reply with quote
Does anyone know where I may find a drive pulley for the above mentioned rake? The one on mine is split and the dia is 5 1/2".
Thanks in advance.
John
DeltaRed
PostPosted: Thu Jul 18, 2013 5:51 am    Post subject: Re: MF DEO 25 hay rake drive pulley Reply to specific post Reply with quote
Not real familiar with that rake..Is the pulley cast,or pressed steel?Cast can besometimes brazed.Pressed steel can sometimes be repaired.There some generic aftermarket suppliers that can provide what you need.JayDee enterprises is a good scourse.There are others as well.
John WVa
PostPosted: Thu Jul 18, 2013 6:32 am    Post subject: Re: MF DEO 25 hay rake drive pulley Reply to specific post Reply with quote
# 667598m91 Sheave Drive four bolt
John Kruer
PostPosted: Thu Jul 18, 2013 2:04 pm    Post subject: Re: MF DEO 25 hay rake drive pulley Reply to specific post Reply with quote
Is that the Massey # or is that another vendor? Would I be able to find it online or my local MF dealer?
Jason S.
PostPosted: Thu Jul 18, 2013 5:57 pm    Post subject: Re: MF DEO 25 hay rake drive pulley Reply to specific post Reply with quote
If it helps you out any the D-EO-20 rake also used the same pulley. What is wrong with the one you have?
John Kruer
PostPosted: Fri Jul 19, 2013 5:14 am    Post subject: Re: MF DEO 25 hay rake drive pulley Reply to specific post Reply with quote
The used rake I bought, the pulley was split/welded/bent/used/hay wraped up in belt/split again and that is what I am working with. It is a sheetmetal/stamped pulley.
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
