Another Hyd. Hose Question
WI Dave
PostPosted: Thu Jul 18, 2013 7:31 pm    Post subject: Another Hyd. Hose Question Reply to specific post Reply with quote
I have a Freeman trip-bucket loader on my 1952 WD. If I replace the old 1/2" hoses to the loader lift cylinders with 3/8" hose, will the loader lift faster? Gain or lose power?
retired farmer
PostPosted: Thu Jul 18, 2013 8:03 pm    Post subject: Re: Another Hyd. Hose Question Reply to specific post Reply with quote
You will have less flow thru the hose because of the smaller diameter.
Leon R2013
PostPosted: Thu Jul 18, 2013 8:20 pm    Post subject: Re: Another Hyd. Hose Question Reply to specific post Reply with quote
Mine came with 3/8 hose and I"m satisfied with it. Leon R
willie in mn
PostPosted: Fri Jul 19, 2013 1:05 am    Post subject: Re: Another Hyd. Hose Question Reply to specific post Reply with quote
Pressure & thus lift force will stay the same. However, due to smaller diameter, oil flow/speed will be approx half.
Willie
Bob Bancroft
PostPosted: Fri Jul 19, 2013 2:05 am    Post subject: Re: Another Hyd. Hose Question Reply to specific post Reply with quote
You won't notice the difference. Except that 3/8" hoses are plenty big enough both for that application, and to have to pay for!
greygoat
PostPosted: Fri Jul 19, 2013 4:43 am    Post subject: Re: Another Hyd. Hose Question Reply to specific post Reply with quote
Lift speed it determined by pump gallon per
minute rating at a specific RPM. putting smaller
inside diameter hose on..chokes the flow down,
makes the pump work harder trying to push flow
through a smaller opening, and results in heat
buildup !
old
PostPosted: Fri Jul 19, 2013 6:02 am    Post subject: Re: Another Hyd. Hose Question Reply to specific post Reply with quote
Going small can/will cause more troubles and there is no reason to go smaller. Stick with the 1/2 inch hoses because the flow will be better and the heat will say lower etc.
LonnAC7050
PostPosted: Fri Jul 19, 2013 2:08 pm    Post subject: Re: Another Hyd. Hose Question Reply to specific post Reply with quote
With the low flow high pressure system of the WD it will work just fine.
