changing fuel tank
RBTXS
PostPosted: Fri Jul 19, 2013 1:52 pm    Post subject: changing fuel tank Reply to specific post Reply with quote
I need to swap my leaky fuel tank with one that doesn"t. My 1955 has a ROPS cab on it. This job requires the cab to be tilted back from the front. How much room is needed to jack it up enough to remove the old tank? I have all of the repair manuals, parts book,and operator"s manual; and there is no info about handling the cab. Any and all advice about this whole job will be appreciated.
J.Wondergem
PostPosted: Sat Jul 20, 2013 5:59 am    Post subject: Re: changing fuel tank Reply to specific post Reply with quote
Not sure on your 1955, but I only had to go about 4 or 5 inches on my 2255.
Don-Wi
PostPosted: Sun Jul 21, 2013 6:55 am    Post subject: Re: changing fuel tank Reply to specific post Reply with quote
Do you know for sure where it's leaking from? This spring i had to replace the rubber gasket under the wire on the sending unit because it was torn. Any time the fender tanks were filled too high, fuel would leak out until it was below the top of the main tank. either from running, or it'd just end up on the ground.
Donovan from Wisconsin
bison
PostPosted: Sun Jul 21, 2013 9:38 am    Post subject: Re: changing fuel tank Reply to specific post Reply with quote
RBTXS wrote:
(quoted from post at 14:52:08 07/19/13) I need to swap my leaky fuel tank with one that doesn"t. My 1955 has a ROPS cab on it. This job requires the cab to be tilted back from the front. How much room is needed to jack it up enough to remove the old tank? I have all of the repair manuals, parts book,and operator"s manual; and there is no info about handling the cab. Any and all advice about this whole job will be appreciated.
If you have the rear entry cab you can remove the whole front panel from it.
