Another 1206 PTO issue
oldtanker
PostPosted: Fri Jul 19, 2013 2:18 pm    Post subject: Another 1206 PTO issue Reply to specific post Reply with quote
PO of my 1206 made a goofy engagement system for the PTO on it. Now my BIL had a 826. Engagement plunger on his PTO pulls up over center to engage. Mine has to go down. I'd like to fix mine so it's right. Any suggestions?
Rick
View user's profile Yahoo Messenger
sd pete
PostPosted: Fri Jul 19, 2013 3:09 pm    Post subject: Re: Another 1206 PTO issue Reply to specific post Reply with quote
Salvage yards have parts.
Owen Aaland
PostPosted: Fri Jul 19, 2013 3:14 pm    Post subject: Re: Another 1206 PTO issue Reply to specific post Reply with quote
oldtanker wrote:
(quoted from post at 18:18:51 07/19/13) PO of my 1206 made a goofy engagement system for the PTO on it. Now my BIL had a 826. Engagement plunger on his PTO pulls up over center to engage. Mine has to go down. I'd like to fix mine so it's right. Any suggestions?
Rick
You have a newer style PTO. Most likely it was originally installed in a late model 86 series tractor or a 3x88 tractor. Probably was changed to get a dual speed PTO. A 1206 was shipped with only a single speed PTO.
oldtanker
PostPosted: Fri Jul 19, 2013 5:25 pm    Post subject: Re: Another 1206 PTO issue Reply to specific post Reply with quote
Owen Aaland wrote:
(quoted from post at 16:14:28 07/19/13)
Rick
OK I do have dual PTO. Any idea of how to fix this or do I need that over center parts from an 86 series tractor?
Rick
pete 23
PostPosted: Fri Jul 19, 2013 5:36 pm    Post subject: Re: Another 1206 PTO issue Reply to specific post Reply with quote
Like Owen said, you have a later style pto. They engage when the plunger goes down. It is locked in by a internal piston and ball mechanism in the valve so therefore you do not need or want an overcenter linkage. If the pressure is not up to snuff they will not stay engaged and also the pressure is not adjustable with the spool like the older style pto's. It has a separate relief valve inside the pto. Those relief valves have a fine screen in them that plugs up and then you don't get good pressure for engagement. The pto may appear to run fine but it just won't stay engaged. Of course, other reasons for low pressure also.
oldtanker
PostPosted: Sat Jul 20, 2013 5:39 am    Post subject: Re: Another 1206 PTO issue Reply to specific post Reply with quote
OK from what you guys have said the lock that keeps it on isn't locking. If forced into the on position it works fine. Just wont shut off all the way.
Rick
