Need Welder's Advice?
Rick Kaufmann
PostPosted: Sat Jul 20, 2013 11:48 am    Post subject: Need Welder's Advice? Reply to specific post Reply with quote
I'm in the process of converting a bush hog from category II to category I. I was going to weld in cat II to cat I bushings in the top link hole of the A-frame. To me, the conversion bushings I bought at Tractor Supply look to be maybe bronze since they have that golden appearance clear through the wall when I cut one in half. It doesn't appear to be a chromate or similar surface finish. Does anyone know the composition of these bushings? Can I weld them with 6011 or would they have to be brazed? Thanks for your help.
Rick
Sparktrician
PostPosted: Sat Jul 20, 2013 11:57 am    Post subject: Re: Need Welder's Advice? Reply to specific post Reply with quote
When you put a magnet to them, do they stick?
Welding man
PostPosted: Sat Jul 20, 2013 12:02 pm    Post subject: Re: Need Welder's Advice? Reply to specific post Reply with quote
Where's your magnet? If they are magnetic. They are steel,probably 1018 Cold Rolled with a anodized or cadimium finish to prevent rusting. 6011 is Ok but not my choice,too brittle, will probably crack out. 7018 is a better choice.
Bus Driver
PostPosted: Sat Jul 20, 2013 1:46 pm    Post subject: Re: Need Welder's Advice? Reply to specific post Reply with quote
They are just mild steel, not high priced alloys.
Bob
PostPosted: Sat Jul 20, 2013 4:48 pm    Post subject: Re: Need Welder's Advice? Reply to specific post Reply with quote
Burn the plating off them without breathing the fumes, sandblast or wirebrush 'em to clean 'em up and weld 'em in place!
rabbit
PostPosted: Sat Jul 20, 2013 6:27 pm    Post subject: Re: Need Welder's Advice? Reply to specific post Reply with quote
I have a top link with cat 1 eye on one end, cat II on the other. Now my tractor is cat II, but you could reverse the proceedure and use a cat II pin, without all the hassle of welding in shims.
Rick Kaufmann
PostPosted: Sat Jul 20, 2013 6:42 pm    Post subject: Re: Need Welder's Advice? Reply to specific post Reply with quote
Thanks guys. Had to run to the hardware to get a magnet. They are definitely ferrous based. Just wasn't sure based on appearances at first. Got them welded in with 7018 and all appears well.
Rick
