John Deere GT 275
gtractorfan
PostPosted: Sat Jul 20, 2013 12:45 pm    Post subject: John Deere GT 275 Reply to specific post Reply with quote
After 15 years of flawless service this afternoon my JD 275's Kawasaki engine surged and died. When I lifted the hood it seemed hotter than normal. I left it sit for a couple hours, then when I went back and looked at it I saw what the problem was. There's a sheet of foil over foam padding under the hood. The foil had come loose and dropped down over where the air shroud fan pulls air to blow over the engine. Thankfully after it was cooled off and I removed the foil it's running normally again. Just a warning for others with this type of set up, beware of the air inlet getting blocked. Would be good to have an engine temperature gauge.
El Toro
PostPosted: Sat Jul 20, 2013 3:17 pm    Post subject: Re: John Deere GT 275 Reply to specific post Reply with quote
I had that problem on my Wards tractor 5 or 6 years ago when I was plowing the garden. Here's what I found causing the overheating. I don't keep any cleaning rags out in the open anymore. What I couldn't snake with a wire I blew out using air pressure. I thought sure I had damaged the engine, but it's still in use. Hal
