Belarus diesel engine tractor
Enar
PostPosted: Sun Jul 21, 2013 9:37 am    Post subject: Belarus diesel engine tractor Reply to specific post Reply with quote
My son and i are in Sweden visiting family. My cousin said his tractor quit. It just shut down and won"t start. My son knows some about diesels and took out the injectors and cleaned them Then he cleaned all the parts up to the fuel tank. Still won"t start. Can anyone help?
View user's profile AIM Address
El Toro
PostPosted: Sun Jul 21, 2013 10:47 am    Post subject: Re: Belarus diesel engine tractor Reply to specific post Reply with quote
Is fuel getting to the injection pump? Could be blockage in the fuel tank. Hal
Enar
PostPosted: Sun Jul 21, 2013 12:47 pm    Post subject: Re: Belarus diesel engine tractor Reply to specific post Reply with quote
Already checked that. It's OK.
El Toro
PostPosted: Sun Jul 21, 2013 3:11 pm    Post subject: Re: Belarus diesel engine tractor Reply to specific post Reply with quote
Pull off the return line and see if any fuel is returning to the tank. Hal
Robert Major
PostPosted: Mon Jul 22, 2013 7:57 pm    Post subject: Re: Belarus diesel engine tractor Reply to specific post Reply with quote
Hi
What model Belarus is it dose it have 4 cyl air cooled 2 cyl air cooled or 4cyl water cooled motor. I need to know this, and I might be able to help. It depends what you are working on.
Regards Robert
Trkr
PostPosted: Fri Jul 26, 2013 3:00 am    Post subject: Re: Belarus diesel engine tractor Reply to specific post Reply with quote
Whatever model Belarus it is,it should have a hand primer pump on the injection pump.You will have to pump it up and bleed it.
Robert Major
PostPosted: Fri Jul 26, 2013 2:09 pm    Post subject: Re: Belarus diesel engine tractor Reply to specific post Reply with quote
Yes that is correct but if it is a rotary pump on a v6 or an air cooled there is an odd ball thing that happens and bleeding it won"t help. Also there is a right way to bleed that rotary pump. been there with pump issues more than once on a 250 and a 420 motor in a co op swather.
Regards Robert
Post new topic    Yesterday's Tractors Forum Index -> Lesser Known Classics All times are GMT - 8 Hours
