2-105 fuel problem
MikeO-WI
PostPosted: Sun Jul 21, 2013 3:55 pm    Post subject: 2-105 fuel problem Reply to specific post Reply with quote
We are rebuilding a 2-105 that had a dash fire about 4 years ago on a cold winter night. It fried the dash but left the cab intact. We have installed a new dash and were having problems getting it to run for more than 5 or 10 seconds. Rebuild the injector pump at the local shop, installed a new transfer fuel pump. Now it runs for about 2-3 minutes and runs out of fuel. Runs really nice but we are starved for fuel and we are getting air. This one is equipped with the fuel fired glow plug. Would that be a problem? We are using a small nurse tank from a lawn mower to power it up and we are thinking of installing the regular tank. Kinda on wits end on this one. Any help would be appreciated.
rrman61
PostPosted: Sun Jul 21, 2013 4:24 pm    Post subject: Re: 2-105 fuel problem Reply to specific post Reply with quote
Are you sure its getting fuel from that small tank and not catching air:just might not be a steady supply.
Paulca
PostPosted: Sun Jul 21, 2013 5:10 pm    Post subject: Re: 2-105 fuel problem Reply to specific post Reply with quote
Where did you hook up your nurse tank to?
MikeO-WI
PostPosted: Tue Jul 23, 2013 4:16 am    Post subject: Re: 2-105 fuel problem Reply to specific post Reply with quote
We hook the nurse tank to the regular fuel line with a hose and clamp. We have used this system many times in the past to test our tractors before installing the main tank. I will check to make sure the mechanic has the clamp on. The injector return line goes directly back to the fuel filters.
Paulca
PostPosted: Tue Jul 23, 2013 7:35 am    Post subject: Re: 2-105 fuel problem Reply to specific post Reply with quote
Why not try hooking it straight on the injector pump? if it runs then you would know your problem is between the tank and the pump????
Captainhookerus
PostPosted: Thu Jul 25, 2013 12:28 pm    Post subject: Re: 2-105 fuel problem Reply to specific post Reply with quote
Sounds as if the return line is not open. Try running with return line disconnected from filters.
MikeO-WI
PostPosted: Thu Jul 25, 2013 6:43 pm    Post subject: Re: 2-105 fuel problem Reply to specific post Reply with quote
can you explain why this would cause the problem.
Captainhookerus
PostPosted: Fri Jul 26, 2013 10:43 am    Post subject: Re: 2-105 fuel problem Reply to specific post Reply with quote
When you get the same pressure on both inlet and outlet of a pump nothing happens.
