Stuck exhaust valve in old Gravely tractor
Goto page 1, 2  Next
Tom in TN
PostPosted: Wed Jul 24, 2013 11:15 am    Post subject: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
I am working on a Gravely walk-behind tractor/mower for a friend of mine. It is the old "L" style tractor that was new in about 1964 or 1965.
The exhaust valve is binding badly. It will come up when I turn the engine over, but will not go back down. If I rotate the engine so that the intake valve is open, I can tap the exhaust valve back down, but it takes a pretty good tap using a piece of 2 X 4 lumber and a mallet.
I have soaked the valve stem for about four days using PB Blaster. I can turn the valve using a pair of pliers, but it turns really hard.
I've turned the engine over and tapped the valve back down into the engine about 20 times and it is still really stuck.
The mower sat outside in the rain. One of the head bolts has been twisted off and there was definite signs of rust inside the head and on the exhaust valve.
Any ideas short of pulling the cylinder and removing the valve from the block?
Thanks,
Tom in TN
El Toro
PostPosted: Wed Jul 24, 2013 2:14 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
Squirt lots of engine oil around the stem and keep rotating the engine. The valve stem may be rusted. Hal
El Toro
PostPosted: Wed Jul 24, 2013 2:18 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
I did that on a Kubota generator that had no compression. I pulled the head and found the exhaust valve stuck. The generator was sitting out on the street for the trash pickup. Engine started on first pull. Hal
Tom in TN
PostPosted: Wed Jul 24, 2013 2:41 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
Thanks Hal,
That's exactly what I'm doing right now, but it seems like it should have loosened up by now. I've been spraying PB Blaster onto the stem and squirting oil also, but to no avail yet.
For now, I guess I'll keep trying the oil and see if it comes around.
Tom in TN
paul n.h.
PostPosted: Wed Jul 24, 2013 3:40 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
try using Liquid Film on it works most of the time for me
Tom in TN
PostPosted: Wed Jul 24, 2013 4:51 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
Paul,
Thanks for the tip. I must admit, though, I've never heard of Liquid Film. Where would I get some of that? I'm open to any and all suggestions.
Tom in TN
jeffcat
PostPosted: Wed Jul 24, 2013 5:14 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
Another product that the truckers use is MotorCoat. I have freed up some pretty stuck stuff with it. Walmart - auto section- bottom shelf- black bottle - $26.oo a quart. Worth every penny. I use it on threads and bearings ETC. Try it. Jeffcat
El Toro
PostPosted: Wed Jul 24, 2013 5:59 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
Some lubri-plate may help. If you have the head off I would pull the valve and take a look at it.
The stem may be rusted from water. Hal
Tom in TN
PostPosted: Wed Jul 24, 2013 7:21 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
Thanks Hal,
Unfortunately, it's a flat head engine. To remove the valve, I'd have to pull the cylinder off the block to get access to the valve spring keeper.
If I can't get it loosened up with lubicant, it looks like I'll have to that.
Tom in TN
Tom in TN
PostPosted: Wed Jul 24, 2013 7:22 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
Thanks Jeffcat,
There's a WalMart about 25 miles from me. If I can't get the valve loosened up pretty soon, I'll try that.
Tom in TN
wwminc
PostPosted: Sat Jul 27, 2013 12:26 pm    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
time for a new valve and guide.
Bret4207
PostPosted: Sun Jul 28, 2013 5:44 am    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
Tom in TN wrote:
(quoted from post at 20:21:13 07/24/13) Thanks Hal,
Tom in TN
IIRC there's a cover that you can open to adjust the valves. Richards Lawn and Garden is the big source for old Gravely stuff in the US. There are a couple of Gravely clubs on line. I'll see if I can remember to find the shop manual and take a look for you.
Traditional Farmer
PostPosted: Mon Jul 29, 2013 4:28 am    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
I've had good luck with Marvel Mystery oil freeing up stuck valves.
Bret4207
PostPosted: Mon Jul 29, 2013 5:44 am    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
On each side of the engine, under the exhaust manifold in this case, right above the crankcase is a small cover with 2 screws holding it on. That's how you access the valve keepers. IIRC you don't have to pull the head at all.
You should get the shop manual for the Gravely.
old
PostPosted: Mon Jul 29, 2013 7:51 am    Post subject: Re: Stuck exhaust valve in old Gravely tractor Reply to specific post Reply with quote
My dad had one of those a long time ago. It was common to have that happen to his and I was pulling the head off all the time due to sticking valves. It got to the point I would fill the cylinder with ATF when he parked it for any long times so that the valves would not stick. I would do that with that one. Fill till it comes out the exhaust and let it sit a few days and then check it out
Goto page 1, 2  Next
Page 1 of 2
