Onan P220 Govenor/ Surgeing
Mike in MI
PostPosted: Thu Jul 25, 2013 5:46 pm    Post subject: Onan P220 Govenor/ Surgeing Reply to specific post Reply with quote
I have JD 420 with the P220 engine and it wants to surge at full throttle with no load. *But Runs fine when under a full load.*
I moved governor spring in all different hole positions seems to make no difference on what I do there.
I also removed top on carburetor and check for any dirt in jets. (was clean) No dirt.
Any help on this subject sure be a welcome! As I ran out of ideas.
Thanks for your help!
Mike
gab
PostPosted: Thu Jul 25, 2013 6:54 pm    Post subject: Re: Onan P220 Govenor/ Surgeing Reply to specific post Reply with quote
Not saying it's your problem but I've got two Onans, a p218 &220 and both have had surging problems. All I've ever done to fix them is spray carb. cleaner in the air horn, where the choke plate is. There's about a half dozen holes around the outside and a couple little holes' air bleeds. Then blow it out with air and go, always has worked for me.
Bob
PostPosted: Thu Jul 25, 2013 8:12 pm    Post subject: Re: Onan P220 Govenor/ Surgeing Reply to specific post Reply with quote
Governor is NOT the problem. As gab told you, carb IS. Check intake manifold, as well.
robert kummer
PostPosted: Fri Jul 26, 2013 4:52 pm    Post subject: Re: Onan P220 Govenor/ Surgeing Reply to specific post Reply with quote
club
there is a known problem with the plastic
flyball spacer ( breaking ) on many of the onan P engines.
i do offer a kit using the older steel spacer,
or the new style plastic one.( with the longer tab
that fits into the notch on the gear.
thank you. boomer ( the used onan engine parts guy )
