Wheel Horse Garden Tractor C-101
fobessteve
PostPosted: Fri Jul 26, 2013 1:00 am    Post subject: Wheel Horse Garden Tractor C-101 Reply to specific post Reply with quote
I am trying to find out. The PTO Belt size for a
rear ejectoin 42"mower deck?
joe csuti
PostPosted: Fri Jul 26, 2013 3:15 am    Post subject: Re: Wheel Horse Garden Tractor C-101 Reply to specific post Reply with quote
According to my lookup the C-101 tractor was built 78-79,my lookup shows two different mod# 42" rear discharge decks used in those yrs,along with two different pn deck drive belts depending on yr,you'll need deck mod# for correct pn belt,you have a couple of options.
1-get mod/sn of tractor off id plate,goto a local toro dealer & have him look up mod# of rear discharge deck used on that tractor & buy/order an oem belt for that mod# deck.
2-IF you have orig belt goto a local bearing supply dealer/napa auto parts & have them measure belt(length x width)and buy a kevlar replacement belt of same size,don't buy a standard generic V belt with nylon/rayon cords as same will give short life due to belt streching/glazing from heat.IF they can't supply a kevlar belt or price seems high versus an oem belt,once you know size of belt(length x width)try going to link below & enter v belt in search,go thru listings & check price in kevlar belt listing for size belt you need,I buy all my replacement belts here.
v belt
JT
PostPosted: Sun Aug 04, 2013 7:47 am    Post subject: Re: Wheel Horse Garden Tractor C-101 Reply to specific post Reply with quote
Depneding on the model of the deck, it could be one of two belts, one is the 102741, 96.7" x 1/2" the most common, the other is a 108834, 98" x 1/2" that one is the least common
