Author |
Message |
jbp Long Time User
Posted: Fri Jul 26, 2013 2:14 pm Post subject: cab overflowing |
The 22-36 runs again after about 30 years of sitting. The problem though is the carb overflows after replacing the float with a new brass float and needle and seat. THe float is adjusted according to included instructions. The float is not leaking and works properly. The new needle and seat in not very well finished with the seating surfaces looking somewhat rough.
What is a good compound to use to get the surfaces properly seated? Valve grinding compound is too coarse, so am thinking of using baking soda or tooth paste as an abrasive. Any ideas? Thanks,
Joe |
Back to top |
jbp Long Time User
Posted: Fri Jul 26, 2013 2:17 pm Post subject: Re: cab overflowing |
Make that carb overflowing, not cab. Joe |
Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 75232 Location: Lake of the Ozarks area of MO
Posted: Fri Jul 26, 2013 4:32 pm Post subject: Re: cab overflowing |
Is the float needle one of those new rubber tipped ones?? If it is open the carb back up. Drop the needle into the seat and tap on it a few times. Then pull it back out and look for a ring around the end of it. You may have to do it a couple times. That is what is called setting the tip learned that years ago from a guy who died years ago |
Back to top |
jbp Long Time User
Posted: Fri Jul 26, 2013 5:11 pm Post subject: Re: cab overflowing |
Thanks old. It is a metal tip so hoping a little laping will make it seat. If not, its 30 dollars down the drain. The old needle had quite a ring worn around it so is beyond repair. i think a lot of these replacement parts come from the land of almost right. Joe |
Back to top |
teddy52food Tractor Guru
Posted: Fri Jul 26, 2013 5:29 pm Post subject: Re: cab overflowing |
I have had success with toothpaste. |
Back to top |
504-1 Long Time User
Posted: Fri Jul 26, 2013 7:36 pm Post subject: Re: cab overflowing |
While you are working on the needle polish up the points on the needle(sides), a lot of the made in China stuff is a little over sized, and they hang in the seat wall. |
Back to top |
EricInSEI Regular
Posted: Sat Jul 27, 2013 9:02 am Post subject: Re: cab overflowing |
And here I thought we had another post about pickups full of trash.
I hope the suggestions work for you. |
Back to top |
