Farmall A gear lube capacities ???
Crazy Horse
PostPosted: Fri Jul 26, 2013 4:30 pm    Post subject: Farmall A gear lube capacities ??? Reply to specific post Reply with quote
What is the capacity of the tranny/differential on a 1945 Farmall A? I assume they are one and the same for using the same oil.
Also need the capacity for the rear PTO unit as well as the belt pulley unit, once again if they are separate and by themselves.
Last one is the capacity of each of the rear axle bull gear oil pans. And with these, does the oil level go up to the fill plug or is it at or below the pan's gasket level?
old
PostPosted: Fri Jul 26, 2013 5:57 pm    Post subject: Re: Farmall A gear lube capacities ??? Reply to specific post Reply with quote
I-T manual says 5 qt for the diff/trans, Final drives 1.5 qts. Add one extra qt for the PTO when you fill the trans/rear
Crazy Horse
PostPosted: Sat Jul 27, 2013 4:19 am    Post subject: Re: Farmall A gear lube capacities ??? Reply to specific post Reply with quote
Thanks for the info, that would likely be US quarts which are pretty close to a litre, just a wee bit smaller(but closer than imperial quarts anyways).
