Two questions about this 1945 Farmall A
jrmartin1964
PostPosted: Sat Jul 27, 2013 5:06 am    Post subject: Two questions about this 1945 Farmall A Reply to specific post Reply with quote
According to its serial number, my Farmall A was manufactured in 1945, and so I would have expected it to have casting codes ending with "O" on the iron components. Quite the contrary, there does not appear to be a single casting code on it anywhere. And instead of an IH H-4 magneto, it has an American Bosch MRD-4A302. Is the lack of casting codes common/typical/normal for a Farmall manufactured in 1945, and could the AB magneto have been a factory option?
BTW, I used my 1947 A for comparison, so I'm fairly certain I have been looking in the right areas for the casting codes.
Jim
View user's profile AIM Address
gene bender
PostPosted: Sat Jul 27, 2013 5:13 am    Post subject: Re: Two questions about this 1945 Farmall A Reply to specific post Reply with quote
Sometimes there just arent any codes ive never read why. The mag has been changed cause it would have left with an I-H mag. Old tractors have had many things changed from original and who could know just why.
1946 BN IHC
PostPosted: Sat Jul 27, 2013 5:27 am    Post subject: Re: Two questions about this 1945 Farmall A Reply to specific post Reply with quote
Jim according to what I see in your picture you have a supper A not just a straight a now that may or may not make a small difference. I like the definition the first gentleman gave as to why the codes. Some times I wish we could pick the brains of the original owners or the mechanics or the plant workers or leaders. I guess we just have to so called, fly by the seat of our pants and use all the information others will have and keep it on file for later generations. I am in the slow process of rebuilding a a B Bn series and my, father is gone, and so I also have to rely on others information also ; thankfully I might add.
Wm.
jrmartin1964
PostPosted: Sat Jul 27, 2013 8:42 am    Post subject: Re: Two questions about this 1945 Farmall A Reply to specific post Reply with quote
gene bender wrote:
(quoted from post at 08:13:07 07/27/13) The mag has been changed cause it would have left with an I-H mag.
I've spent a fair amount of time since my original posting scouring of the internet, and I turned up information that American Bosch supplied the MRD-4A302 magnetos to International Harvester, which was used on U-1, U-2, U-4, and U-6 power units, I-4 and I-6 industrials, and T-6 crawlers. So perhaps my mag was 'borrowed' off of one of those sometime in its past.
Wm. Ecccles - Jardine wrote:
(quoted from post at 08:27:27 07/27/13) Jim according to what I see in your picture you have a supper A not just a straight a
It's probably the angle of the photo, but I can assure you it is definitely an A. No hydraulics, just a plain ol' A. The rockshaft for hand lift and the battery box kind of make the space under and to the rear of the gas tank look like it's filled in with a Touch-Control.
gene bender
PostPosted: Sat Jul 27, 2013 11:19 am    Post subject: Re: Two questions about this 1945 Farmall A Reply to specific post Reply with quote
Dont see very many with the rod going back to the rear tooling from the lift levers usually had a lever on the drivers platform for the rears.
jrmartin1964
PostPosted: Sat Jul 27, 2013 2:43 pm    Post subject: Re: Two questions about this 1945 Farmall A Reply to specific post Reply with quote
By the time I came to own this tractor the lift had been subjected to a previous owner's ingenuity and a cutting torch, and had been converted to hydraulic operation with the addition of a power steering pump scabbed onto the generator bracket and a cylinder attached to what remained of the operating levers. I located most of another lift (which had also had an encounter with a torch), of the same type at a salvage yard which had the levers and counterbalance springs and some other parts that I needed. The latching rods, however, I had to fabricate. A buddy of mine had a copy of the manual for this particular lift, and that was a great help in getting it all back together correctly.
