Briggs 16hp vanguard v-twin starter
DENNIS SNYDER
PostPosted: Sun Jul 28, 2013 7:37 am    Post subject: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
This message is a reply to an archived post by joe csuti on September 29, 2012 at 16:51:30.
The original subject was "Re: Briggs 16hp vanguard vtwin starter".
HI I NOTESED YOUR COMMENT I HAVE THAT PROBLEM FLYWHEEL ALUNIUMN RING GEAR IS SHOT . SOMEONE USED AN METAL TEATH ON STARTER .LOOKING FOR FLYWHEEL OR RING GEAR CHEAP THS DENNIS
joe csuti
PostPosted: Sun Jul 28, 2013 2:06 pm    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
Before buying just any flywheel for a 16hp vanguard eng,get mod/type numbers off eng & goto link below & look up your eng for correct flywheel pn & also check if aluminum ring gear avail seperate,if it is consider buying a new gear and replace or take flywheel to a local machine shop to have replaced if gear not bolted to flywheel.
Problem being the vanguard twins used seven different alt stators & three flywheels with different size magnets,depending on alt stator on eng & size of magnets in flywheel you may have charging issues if stator/flywheel magnet size not matched.
briggs
Anon
PostPosted: Mon Jul 29, 2013 5:10 am    Post subject: Re: Briggs 16hp vanguard v-twin starter Reply to specific post Reply with quote
If I remember correctly- just the ring gear is available. Very easy to change.
