Author |
Message |
JD B Mech Regular
Posted: Mon Aug 05, 2013 2:58 pm Post subject: AC G Implements |
I recently inherited a pretty nice 48" G which was restored about 15 years ago. It"s been kept inside and still looks good, but hasn"t run in several years.
Included in the package was a 12" right-hand plow, grader blade, two shop-made ditching implements (see photos), a store-bought spike-tooth harrow which has been adapted to fit a G, and a complete cultivator mounted on the tractor. I also have an implement adjusting lever which I can"t identify.
I"m debating selling the entire outfit or possibly keeping the tractor w/mounted cultivator and selling the loose implements. I"ve done several hours of on-line research to try to determine ball-park values of this stuff and am not having much luck. My questions are:
1. Is it more advantageous to sell the tractor with all of the implements or break it up and sell things individually?
2. Are AC G implements a rarity and hard to find?
3. Based on the photos, can anyone give me a realistic ballpark estimate of what each item is worth?
Yeah, I know that last question makes your blood boil and I hate to ask it, but please cut me some slack.........I"m a JD two-cylinder tractor guy and this is my first experience with AC.
Thanks in advance for your input and I look forward to your replies.
Back to top |
Lonnie Smith Regular
Posted: Mon Aug 05, 2013 6:07 pm Post subject: Re: AC G Implements |
The homemade implements probably not worth much if anything, a right hand plow you can buy for $150-$200. I'm not sure the adjusting handle is for a G, could be from something else and made to work on it but I could be wrong? If you have a full set of cultivators then that is probably the most valuable implement. The implements are probably worth more sold seperatly than with the tractor. |
Back to top |
MoMac Regular
Posted: Tue Aug 06, 2013 3:29 am Post subject: Re: AC G Implements |
Pretty sure that the adjusting lever is off a Farmall Cub for the breaking plow. Looks just like the one I have on my Cub. |
Back to top |
JD B Mech Regular
Posted: Wed Aug 07, 2013 5:44 am Post subject: Re: AC G Implements |
Thanks Lonnie, I appreciate it! |
Back to top |
JD B Mech Regular
Posted: Wed Aug 07, 2013 5:46 am Post subject: Re: AC G Implements |
I think you're right........my grandfather had a Farmall Cub at one time and this lever probably got mixed in with the AC G stuff. Thanks for your input! |
Back to top |
mike mckee Guest
Posted: Wed Sep 18, 2013 7:22 pm Post subject: Re: AC G Implements |
interested if you decide to sell the grader blade |
Back to top |
