4230 vibration
foxhoun
PostPosted: Tue Aug 06, 2013 2:22 am    Post subject: 4230 vibration Reply to specific post Reply with quote
Just looking for a place to start.My John Deere 4230 has developed a vibration of some kind when I am running the 540 pto only.It smooths out when going down hill but starts to vibrate as soon as the tractor is in a strain.I do not notice the vibration when running the 1000 rpm pto.
Any ideas?
johnpop1
PostPosted: Tue Aug 06, 2013 2:47 am    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
I would guess that the vibration is coming from the PTO clutch. I believe that there is more torque in the PTO when it is run at 540 and therefore it is more likely that the clutch is slipping.
dustycoal
PostPosted: Tue Aug 06, 2013 3:09 am    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
Have you hooked up another machine to isolate to the tractor and not the drive line of the machine your hooked to? Only a though as I don't have that tractor.
cannonball
PostPosted: Tue Aug 06, 2013 3:17 am    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
have you replaced the harmonic balancer...
Roger in Iowa
PostPosted: Tue Aug 06, 2013 3:19 am    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
Torque on clutch will be the same whether 540 or 1000, only if load is different. Clutch turns same rpm for either.
Tx Jim
PostPosted: Tue Aug 06, 2013 4:43 am    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
I'd inspect the drive shaft attached to the implement for bad u-joint or bending. Did you try pulling same implement with a different tractor to see if vibration continued or went away? Does drive shaft happen to have a CV joint?
foxhoun
PostPosted: Tue Aug 06, 2013 2:15 pm    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
There is no cv joint.The only 540 pto I have is on my baler.I have not checked the u joints mostly because the tractor seems to be laboring more than usual when the vibration exists.I will pull the shaft off the baler and inspect it.
ss55
PostPosted: Tue Aug 06, 2013 3:50 pm    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
That does sound like a bad U-joint. Luckily, that would also be the easiest and least expensive thing to fix if one is bad.
Have someone else run the baler as you walk along side and listen to the U-joints when the baler works hard. One U-joint may be chattering pretty loudly by now if you can feel the vibration at the tractor seat. Your tractor has a Sound-Guard cab?
foxhoun
PostPosted: Tue Aug 06, 2013 4:53 pm    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
no cab just canopy
thanks
foxhoun
PostPosted: Sun Sep 01, 2013 5:24 am    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
Thanks everyone for he input.I found a bearing in the tongue of the baler that was the problem.
Foxhoun
foxhoun
PostPosted: Fri Sep 06, 2013 3:16 am    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
The vibration is getting worse.It seems to be coming from the the tractor.I have used 2 different implements.It increases when going up a hill and seems to cause tractor to loose power.It vibrated with the 540 and 1000 rpm shaft.
Any ideas where to start would be a big help
foxhoun
PostPosted: Sat Oct 12, 2013 4:55 am    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
Well I am back looking for help again.The vibration is coming from the engine.It seems to be a fuel issue.I have changed the fuel filter 3 times and drained the fuel tank.The vibration still exists when under a load.Yesterday I noticed what looked to be rust in bottom of the glass filter but no water was seen.Any ideas other than keep changing the filters which cost $15.00 each.
Tx Jim
PostPosted: Sat Oct 12, 2013 5:18 am    Post subject: Re: 4230 vibration Reply to specific post Reply with quote
Have you periodically checked for water in fuel tank by opening drain cock on bottom of the fuel tank?
