5000 doing it again!!!
vtjoe
PostPosted: Wed Aug 07, 2013 6:55 am    Post subject: 5000 doing it again!!! Reply to specific post Reply with quote
"still", maybe more accurate! My 5000 super major while working at some minimum to moderate RPM will all of sudden go into race mode and I mean it happens fast! only solution is to shut off fuel and restart, then it is OK...and will idle down correctly. (for a while) I suspect malfunction with the Simms Minimec fuel pump (non vacuum governor type) it must be centrifugal???? and getting stuck under load I don't want to blow it up so I am looking for a good fuel injection pump re-builder around southern Vermont
any thoughts??? any recommendations?
jimont
PostPosted: Wed Aug 07, 2013 11:38 am    Post subject: Re: 5000 doing it again!!! Reply to specific post Reply with quote
Have you been changing the oil in the cam-box in the injection pump every 100hrs.?
That seems to be an area that is overlooked way too often. If not,drain it and install oil (same as your engine oil).
Dieseltech
PostPosted: Wed Aug 07, 2013 12:00 pm    Post subject: Re: 5000 doing it again!!! Reply to specific post Reply with quote
Sounds like the cam bearings are bad in the pump. Will cause the trouble you have.
vtjoe
PostPosted: Fri Aug 09, 2013 5:03 am    Post subject: Re: 5000 doing it again!!! Reply to specific post Reply with quote
diesel tech..... i assume that it needs a rebuild?? does any one have a schematic of the Simms pump?
when it is not trying race it runs quite well.
any re-builders in northern Mass southern New Hampshire you could recommend?
vtjoe
PostPosted: Fri Aug 09, 2013 5:06 am    Post subject: Re: 5000 doing it again!!! Reply to specific post Reply with quote
oil will be changed this weekend in the pump thanks for replys
Dieseltech
PostPosted: Sat Aug 10, 2013 7:29 pm    Post subject: Re: 5000 doing it again!!! Reply to specific post Reply with quote
If you can't find anyone that knows the Simms pump I could check it out for you. See how it acts after an oil change, you may have gotten lucky.
vtjoe
PostPosted: Wed Aug 14, 2013 10:38 am    Post subject: Re: 5000 doing it again!!! Reply to specific post Reply with quote
after dieseltech said to change the oil, i did and found
1- it was over full(brownish looking... means water)
2- Dave at New England Injection said the centrifugal governor balls will try to float when over full messing up the intended action
3- possible broken governor spring-- easy fix
Thanks for replies, I will post results soon as I am healing a sprained ankle (clutch foot)
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
