Which one is it 15-30 or 22-36
Dave Garlock
PostPosted: Mon Aug 12, 2013 6:58 am    Post subject: Which one is it 15-30 or 22-36 Reply to specific post Reply with quote
Dad and I just bought an old McCormick Deering but we are not sure what we have. The serial number tag on the fuel tank support is pretty much destroyed. I found an engine SN 110080 on the right front of the block. It has a Robin S45 carb. There is a casting number on the main casting 758-D. Can anybody help with year and model?
rustred
PostPosted: Mon Aug 12, 2013 7:21 am    Post subject: Re: Which one is it 15-30 or 22-36 Reply to specific post Reply with quote
you can find the year, month and date by crawling under it and looking at cast under flywheel. easiest thing is if it has water pump its 22-36, 15-30 had none. 22-36 also have oil filter, larger bore and more rpm. this is a few of the change ups from 15-30.
Old-F20
PostPosted: Mon Aug 12, 2013 9:53 am    Post subject: Re: Which one is it 15-30 or 22-36 Reply to specific post Reply with quote
serial number TG99926 and up were the 22-36
rustred
PostPosted: Mon Aug 12, 2013 9:54 pm    Post subject: Re: Which one is it 15-30 or 22-36 Reply to specific post Reply with quote
he said his tag was destroyed.
Old-F20
PostPosted: Tue Aug 13, 2013 7:05 am    Post subject: Re: Which one is it 15-30 or 22-36 Reply to specific post Reply with quote
rustred wrote:
(quoted from post at 22:54:38 08/12/13) he said his tag was destroyed.
I know, I read that, but why repeat what you said about the water pump.
he has an engine serial so that's why I put it on there
Dave Garlock
PostPosted: Wed Aug 14, 2013 6:22 am    Post subject: Re: Which one is it 15-30 or 22-36 Reply to specific post Reply with quote
It has a water pump so I guess that makes it a 22-36. I don't get the TG reference in front of the engine SN. Mine doesn't have a TG in front. Any ideas on the year?
Nebraska Kirk
PostPosted: Wed Aug 14, 2013 4:29 pm    Post subject: Re: Which one is it 15-30 or 22-36 Reply to specific post Reply with quote
Dave Garlock wrote:
(quoted from post at 08:22:18 08/14/13) It has a water pump so I guess that makes it a 22-36. I don't get the TG reference in front of the engine SN. Mine doesn't have a TG in front. Any ideas on the year?
The serial number prefix "TG" was only used on the serial number tag, not on the engine block,
Serial number 110080 was made in March of 1929.
36F30
PostPosted: Wed Aug 14, 2013 4:45 pm    Post subject: Re: Which one is it 15-30 or 22-36 Reply to specific post Reply with quote
Dave Garlock wrote:
(quoted from post at 07:22:18 08/14/13) It has a water pump so I guess that makes it a 22-36. I don't get the TG reference in front of the engine SN. Mine doesn't have a TG in front. Any ideas on the year?
Assuming you have the original engine, ( serial number and engine numbers match) The tractor was made in March of 29.
The 15-30 and the 22-36 had a TG prefix on the tag. The serial number that should be on your tag should have read TG110080M.
All the tractors had a prefix to designate the model within the serial "number". For instance the Industrial 10-20 had a IN prefix, the 10-20 farm tractor was KC, and the narrow tread 10-20 was NT.
Old-F20
PostPosted: Wed Aug 14, 2013 6:45 pm    Post subject: Re: Which one is it 15-30 or 22-36 Reply to specific post Reply with quote
36F30 wrote:
(quoted from post at 17:45:31 08/14/13)
nope. first two years of the model 20 industrial had serial numbers and prefixes that ran concurrent with the Ag tractor, therefor having a KC prefix. Stop over Friday and ill show you one Brian....lol
model 20's had 4 prefixes throughout production.
KC, IND, IN and SIN
