Help wiring indicator light
Old Fossil
PostPosted: Wed Aug 21, 2013 1:02 pm    Post subject: Help wiring indicator light Reply to specific post Reply with quote
I'm nearly complete with a 1946 9N restoration and I wanted to add an indicator light to remind me if the ignition switch has been left on. I purchased a small LED type 12v indicator light and checked to see it worked with my 6v positive ground set up. Wired direct through the battery it lit nicely. Now I want to wire it to be on when the key is on. As simple as it seems, It won't light up for me. I have one lead from the light hooked to the resistor block terminal which accepts the ignition switch lead, and the other lead form the light goes directly to ground. All connections clean and tight. Any suggestions?
JMOR
PostPosted: Wed Aug 21, 2013 1:13 pm    Post subject: Re: Help wiring indicator light Reply to specific post Reply with quote
Old Fossil wrote:
(quoted from post at 17:02:28 08/21/13) I'm nearly complete with a 1946 9N restoration and I wanted to add an indicator light to remind me if the ignition switch has been left on. I purchased a small LED type 12v indicator light and checked to see it worked with my 6v positive ground set up. Wired direct through the battery it lit nicely. Now I want to wire it to be on when the key is on. As simple as it seems, It won't light up for me. I have one lead from the light hooked to the resistor block terminal which accepts the ignition switch lead, and the other lead form the light goes directly to ground. All connections clean and tight. Any suggestions?
LED is polarity sensitive......try reversing the leads.
Old Fossil
PostPosted: Wed Aug 21, 2013 1:17 pm    Post subject: Re: Help wiring indicator light Reply to specific post Reply with quote
Thank you JMOR, It Works! ( I new it had to be something simple )
JMOR
PostPosted: Wed Aug 21, 2013 1:56 pm    Post subject: Re: Help wiring indicator light Reply to specific post Reply with quote
Old Fossil wrote:
(quoted from post at 17:17:51 08/21/13) Thank you JMOR, It Works! ( I new it had to be something simple )
You are welcome!
