Lower link advice
Abbby
PostPosted: Wed Aug 21, 2013 5:41 pm    Post subject: Lower link advice Reply to specific post Reply with quote
So my lower left link arm is leaking oil and both are kind of worn out. I am thinking about replacing just the left one but then think about while I have it apart replacing both. Right is dry as can be so kind of hate to create a problem. seems both are pretty worn out. Thoughts? What sealant would I use to make sure things are sealed up good? What is the best pin to buy? Hate to buy a cheap one. This is a working tractor.
DollarBill
PostPosted: Thu Aug 22, 2013 12:35 am    Post subject: Re: Lower link advice Reply to specific post Reply with quote
Replace both of them if they are worn out - Sponsors should carry good quality parts.
I would use the #1 Permatex Form-A-Gasket.
Ken N Tx
PostPosted: Thu Aug 22, 2013 2:31 am    Post subject: Re: Lower link advice Reply to specific post Reply with quote
DollarBill wrote:
(quoted from post at 04:35:33 08/22/13) Replace both of them if they are worn out - Sponsors should carry good quality parts.
Ditto replace both..
9N or 8N ?? There is a difference..8N is tapered and does not need sealant unless the hole is worn out.
Abbby
PostPosted: Thu Aug 22, 2013 3:00 am    Post subject: Re: Lower link advice Reply to specific post Reply with quote
It is a 9N. Do I need to replace 9N562 and 9N563? Seems like just the pin. Do you reccomend the gasket only for the trumpet and sealer on the pin parts?
souNdguy
PostPosted: Thu Aug 22, 2013 9:20 am    Post subject: Re: Lower link advice Reply to specific post Reply with quote
if both worn.. and ou are going in for 1 leaker.. replace both..
Jim.UT
PostPosted: Sat Aug 24, 2013 12:07 pm    Post subject: Re: Lower link advice Reply to specific post Reply with quote
I have some used ones. The link is to a pair I have
on ebay, but I have others on the shelf.
ebay listing
Abbby
PostPosted: Sat Aug 24, 2013 2:13 pm    Post subject: Re: Lower link advice Reply to specific post Reply with quote
So can the 9N pin only be replaced or must the small casting go with it? Is it one piece?
Abbby
PostPosted: Tue Aug 27, 2013 6:33 pm    Post subject: Re: Lower link advice Reply to specific post Reply with quote
Does the 2N and 9N only come as an assembly or can the pin be replaced?
R Geiger
PostPosted: Tue Aug 27, 2013 6:45 pm    Post subject: Re: Lower link advice Reply to specific post Reply with quote
Check the parts listing for it on this site. Only shows the pin and the gasket.
