8N Hydraulic oil question
Dave S.
PostPosted: Wed Aug 21, 2013 7:54 pm    Post subject: 8N Hydraulic oil question Reply to specific post Reply with quote
Would universal hydraulic oil work in a 8N without doing any damage? it is used mostly to push snow, plow & disk a small garden and to run a small brush hog to trim around fences. Want to get away from the slow hydraulics in the winter.
View user's profile AIM Address
Royse
PostPosted: Wed Aug 21, 2013 8:01 pm    Post subject: Re: 8N Hydraulic oil question Reply to specific post Reply with quote
Yellow metal safe Universal Tractor Fluid is fine as long as it meets
or exceeds Ford spec M2C134D. Most do, and it will say so on the label.
You can find it at TSC, Wal-Mart, etc.
It is thinner, so you may notice more leaks.
Bob
PostPosted: Wed Aug 21, 2013 8:58 pm    Post subject: Re: 8N Hydraulic oil question Reply to specific post Reply with quote
Royse... IS there such a thing as UTF that is NOT "yellow metal safe"?
IMHO, the "yellow metal safe" issue applies to GEAR OIL, usually GL-5.
Royse
PostPosted: Thu Aug 22, 2013 3:36 am    Post subject: Re: 8N Hydraulic oil question Reply to specific post Reply with quote
Not that I'm aware of personally.
TheOldHokie
PostPosted: Thu Aug 22, 2013 5:50 am    Post subject: Re: 8N Hydraulic oil question Reply to specific post Reply with quote
Bob wrote:
(quoted from post at 00:58:11 08/22/13) Royse... IS there such a thing as UTF that is NOT "yellow metal safe"?
IMHO the concern over EP corrosivness in an N series is way over blown. There are no synchronizers which are the most vulnerable type of component and what little yellow metal is there (PTO cam blocks) doesn't get anywhere close to the surface pressures and temperatures that activate the EP additives. In any event with a few exceptions most modern GL-5 formulations are buffered and not particulalrly corrosive. Here is a list of ASTM D130 copper strip corrosion test results for some common gear lubes. Test results range from 1A (non-corrosive) to 4C (highly corrosive). Most of these lubes are 1B which is just a light stain - e.g. yellow metal safe in most synchronized transmissions and certainly OK in an N-series
Code:
M/T FLUID & GEAR OIL  WEIGHT  API  CLASSIFICATION
Amsoil Long Life FGR  75W-90  GL5  1B Dark Orange
Amsoil Severe Gr SVG  75W-90  GL5  1B Dark Orange
Amsoil M/T Fluid MTF   5W-30       1A Light Orange
Amsoil MT & Gear MTG  75W-90  GL4  1B Dark Orange
Castrol Hypoy C       80W-90  GL5  1B Dark Orange
Castrol SYNTEC        75W-90  GL5  1B Dark Orange
Citgo Citgear Std XD  75W-90  GL4  1B Dark Orange
Delo Gear Lubric ESI  80W-90  GL5  2A Claret Red
Delo Trans Fluid ESI  50W          2A Claret Red
GM Synthetic Axle     75W-90  GL5  1B Dark Orange
Lucas 75/90 Synthetic 75W-90  GL5  4B Graphite Blk
Mobil 1 Synthetic     75W-90  GL5  1B Dark Orange
Mopar Synthetic
w/Mopar LS additive   75W-90  GL5  4A Trans Black
Pennzoil Gearplus     80W-90  GL5  1B Dark Orange
Pennzoil Synthetic    75W-90  GL5  1B Dark Orange
Red Line MT-90        75W-90  GL4  1A Light Orange
Red Line NS Gear Oil  75W-90  GL5  1B Dark Orange
Red Line 75W90 GL-5   75W-90  GL5  1B Dark Orange
Royal Purple Max-Gear 75W-90  GL5  4A Trans Black
Torco SGO Synthetic
w/Torco Type G LS add 75W-90  GL5  1B Dark Orange
Valvoline High Perf   80W-90  GL5  1B Dark Orange
Valvoline SynPower    75W-90  GL5  1B Dark Orangee
